Heated Seat Repair
Old Nov 22, 2011 | 01:03 PM
Steve - UK's Avatar
Default Heated Seat Repair
Has anyone had any experience of using a repair kit to rectify heated seat failure. I did see some repair kits on the market a while back - are these available anywhere now?
I understand that the heating element is bonded to the inside of the leather seat covers and when I had this job under warranty a while back on previous car they changed the covers. But the repair kit has new elements to put in (I think) Any experience on this will a big help!
Old Nov 22, 2011 | 02:50 PM
32krazy!'s Avatar
Default Re: Heated Seat Repair
give buggin a shout. he did his seats a while back and has all the info needed
Old Nov 22, 2011 | 03:02 PM
FUBU's Avatar
I have done it aswell. There are some repair kits from chrysler. But also from aftermarket. It takes about 3-4 hrs a seat the first time. I did it for my N/A 2 yrs ago. Must do for my SRT6 soonish.
Old Nov 22, 2011 | 04:23 PM
Steve - UK's Avatar
Can you recommend a repair kit at all - did the repair do a good job and last?
Old Nov 23, 2011 | 03:11 PM
FUBU's Avatar
I bought the oem from Chrysler. Worked very well. You do
Need to have a glue gun and solder iron. And time.
Old Nov 24, 2011 | 11:05 AM
muskrat's Avatar
You're English, you don't need a warm *rse . Stiff upper lip etc. Mines not worked since I got it and even SWMBO turned hers off sharpish claiming to be frying tonight!
Old Nov 24, 2011 | 12:13 PM
Steve - UK's Avatar
Hmmm I will relay your comments to my lady friend! and then take cover!
Old Nov 24, 2011 | 06:56 PM
jsaredwings's Avatar
any reason why the seat back heats up but not the base of the seat? elements burning out? electric relays? wiring?
Old Nov 25, 2011 | 07:10 PM
bri3d's Avatar
Wiring, but sadly wiring inside of the seat, so you need to physically pull the seat apart and sew it back together to fix.
Check out https://www.crossfireforum.org/forum...structions.pdf - this is a common enough issue that it was a TSB, and that's the Chrysler guide.
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
atdavis2
Sep 21, 2015 01:25 PM
jaesa
Sep 7, 2015 01:50 PM
