to remove the engine cover?
Old Sep 7, 2012 | 07:34 PM
Chadders's Avatar
Default to remove the engine cover?
Hi there, how do you remove the large silver engine cover from an 04 coupe non-SRT? Kind regards
Old Sep 7, 2012 | 08:00 PM
Bear505's Avatar
Default Re: How to remove the engine cover?
Just pull on it... I started at the back left corner, and worked my way around... It's held on with rubber Grommets...
A little WD40 when you put it together makes it easier to take off next time..
Old Sep 7, 2012 | 08:54 PM
Be sure when putting it back on that you are sure to line it up with the throttle body at the center in back with the opening on the cover and create a good seal
This is where the air flows from the filters to the engine.
Old Sep 7, 2012 | 10:17 PM
Chadders's Avatar
Default
Thank you very much! I was checking the levels etc today and was looking how to remove it to check my air filters but it looked quite secure!
Old Sep 7, 2012 | 10:33 PM
WD40 will help you get it on but dries up quickly, but a little white grease on the clips will help you get it on and off later much better.
Old Sep 8, 2012 | 06:46 AM
Bear505's Avatar
Yea... probably a better Idea for the long term.....
Old Aug 3, 2013 | 06:16 PM
RA12625's Avatar
Banned
Default Re: to remove the engine cover?
What is white grease and if I ask for it at O'Reilly's will they know what I mean? Thanks!
Old Aug 3, 2013 | 07:05 PM
White grease is Lithium grease.
reiji
Oct 15, 2015 10:50 PM
Mopar or No Car
Aug 11, 2015 08:11 AM
RED DOG
Jul 21, 2015 07:58 AM
cjfine
Jul 20, 2015 11:58 PM
jtr2901
Jul 10, 2015 06:33 PM
