how to reset check engine light
Old 03-01-2013, 12:15 PM
tdm1953's Avatar
Cool how to reset check engine light
How can i reset check engine light 06 crossfire limited.Advance auto scanner says its in the evaporatve emissions return line [aka,gas cap or possible vent line leak]I`ve retightened gas cap, light still on.We`ve also noticed fuel gage not registering properly.Any help or advise is appreciated.:
Old 03-01-2013, 12:21 PM
witchal's Avatar
Default Re: how to reset check engine light
Disconnect the battery to clear the codes. Fuel gage? Don't know that one
Old 03-01-2013, 12:39 PM
robby363's Avatar
It might be time for a new gas cap. I was getting a code like that and after I replaced the cap the code never came back.
Old 03-02-2013, 12:35 AM
JEFASOLD's Avatar
Get yourself an inexpensive OBDII reader, this will allow you to reset the codes. Many CELs will not reset by hemselves. This is if you don't want to get an Ultragauge or Dashdaq, etc.
Old 09-13-2017, 11:00 AM
I have a code 730 on my 2004 crossfire.
any ideas? Manual trans. Just changed alternator
Old 09-13-2017, 11:16 AM
robby363's Avatar
Is the code you're seeing showing in the mileage window when you first start your car? Or is it a P0730 code on a reader?
Old 09-13-2017, 11:26 AM
Should have said it's a double Wrench code and -730.
Old 09-13-2017, 12:16 PM
robby363's Avatar
That is telling you that you are 730 miles overdue for a oil change.
Old 09-13-2017, 12:24 PM
I had the oil changed about 1000 miles back.
I tried the reset everyone talks about to no
avail. My obdII won't interface for some reason
so I guess I'll take it to autozone to reset.
Old 09-13-2017, 01:34 PM
Good luck with that ! ( the Autozone people are gonna look at you with a stupid expression on their face )
This is not re-settable via the ODBC port, it is done via a **** on the dash.
The problem usually is that since this **** switch is used so seldom, it gets dirty and does not make good contact.
Here are the owner's manual instructions :
The counter can also be reset by any individual after the
indicated service has been performed. To do so:
1. Turn key to the ON/RUN position.
2. Within one second press the ****/button twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/LOCK.
4. Press and hold the ****/button, while turning the key to ON/RUN again.
The present status for days or distance is displayed once more. Continue to hold the ****/button.
After approximately 10 seconds, a signal sounds and the display shows 7,000 miles (Canada: 11,000 km) for approximately 10 seconds.
5. Release the ****/button.
Old 09-13-2017, 04:40 PM
You had better tell him what **** to press.
Old 09-13-2017, 04:46 PM
Steve Jr's Avatar
Looking at the dash its the **** on the left. Double wrench , means it time to lube an maintenance other parts of the car. Not only oil change.
2004_
04-08-2019 09:51 AM
jgreen
106
09-18-2017 11:46 PM
spoiler
09-02-2015 08:56 PM
axnguyen
07-21-2015 11:41 AM
Mark McKay
07-17-2015 01:18 PM
Quick Reply: how to reset check engine light
