Oil Change
Old Jun 28, 2008 | 05:38 PM
  #41 (permalink)
sowardcustoms's Avatar
Default Re: Oil Change
the drain plug gasket chrysler number is 5073946AA
Old Jun 28, 2008 | 07:31 PM
  #42 (permalink)
this was a grt updated thread, saved me searching for answers...I only put about 4k a yr on mine...and I will attempt my 1st oil change before I go to WWDC in Aug...dealer gave me a yrs worth of oil changes...grt deal...they changed it once...yrs up...should have asked for free gas...thanks all who contributed grt read...
Old Jun 29, 2008 | 07:54 PM
  #43 (permalink)
doc clock's Avatar
Talking Re: Oil Change
just changed my oil and filter on 2005 coupe.did not even put car on lift.reached under with 10mm ratchet set up.removed four bolts and dropped cover.then reached in from front of car and removed drain plug.replaced plug/cover and changed filter assy.had paper filter and four o rings. of varying sizes.was easy and saved about$65 dollars,and did not have to worry about some igmo scratching my car.good luck
Old Jun 30, 2008 | 07:56 AM
  #44 (permalink)
Rob M's Avatar
i just did mine for the first time this weekend. it wasn't difficult at all and not as messy as many other vehicles. i used a paper Purolator Pure 1 One filter (made in India). i used a rubber strap filter wrench to loosen the filter housing. total cost was approx. $50 (filter plus 8qts Mobil 1 0W-40). still need to check level to see if i should add another 1/2 qt - though FSS monitor says "ok". i used ramps to have a little easier access.
even though the rubber o-rings aren't difficult to remove, i wonder if it's actually necessary to replace them each time filter is replaced?
minimayhem
16
Aug 23, 2016 07:47 AM
csteve0355
Sep 23, 2015 05:57 PM
lazorouss
Sep 11, 2015 09:16 AM
MickeyNasty
Sep 6, 2015 08:29 PM
PNA
Sep 5, 2015 02:20 PM
