Replacing the sway bar bushings at front
Old Mar 19, 2022 | 05:02 PM
Astrofriend's Avatar
Default Replacing the sway bar bushings at front
Now we are almost in the spring and it's time to fix some problem with my car. The sway bar's rubber bushing in the front are not good and I need to replace them. When I did that I investigated what's behind the front fender, a lot of dirt !
Some photos and text about this:
2005 years Chrysler Crossfire: Replacing the sway bar bushings at front
I'm glad I found the dirt behind the fender, it could have caused a rust hole !
/Lars
Old Mar 20, 2022 | 01:40 PM
bluecoupe's Avatar
Default Re: Replacing the sway bar bushings at front
Nice job, thanks for posting your link!
Old Mar 20, 2022 | 02:52 PM
The inner fenders should be loosened and the mud behind them washed away, you will be surprised how much is deposited there by the cowel drains and wheel spray. I changed the WS washer reservoir and I was stunned at the amount of dirt behind the fender liner. I cleaned it and covered the area with that anti rust spray, CLEAR FILM.
I also used it on the inside bottoms of the doors, water on the exterior of the rear side windows is diverted to the inside of the doors and drains out of the door bottom, weird.
spray the underside of the car with the hose to fem over built up mud and silt, it is best done when the car is still damp from a drive in the rain.
Also clean the mud that accumulates on the top of the fender lip, this is a primes spot for rust holes on cars in wet climates like the UK. Also wash the areas were the inner liner screws are as mud collects there.
It is best to do this after the car has been driven in the rain as hose water just rolls of the dried mud. Look at the rear wheel area as well.
Keep that mud off the car and rust problems will be minimized.
Old Mar 24, 2022 | 07:42 AM
One warning about rust protection. I rust protected the rear hatch, after that the lock mechanism got stuck, luckily in the open position. I have to take apart the lock mechanism and clean everything from rust protection. But now I have stopped the rust.
/Lars
Old Feb 15, 2026 | 12:22 PM
/Lars
Thank you for the post. I will have to replace mine very soon.
ardenian
Jul 21, 2018 12:53 PM
dayjor
Jun 6, 2014 11:20 PM
JesseJamessrt6
81
Jul 12, 2013 04:16 PM
hcarter
Apr 23, 2012 08:48 AM
hcarter
Dec 4, 2011 09:03 AM
