Light control module / illumination control module
Does anyone know the part number for the light control module on a 2003 xfire?
Also does the car share the same part as an SLK? |
Re: Light control module / illumination control module
Also does the car share the same part as an SLK? If you mean the light switch, this comes complete with the fuse box that sits behind it on the inside of the dash and is accessible from the panel on the end of the dash. It is an SLK320 part and is readily available for your local dealer. But is expensive. |
