Crossfire Electric issues/Garage recommend Please - South Wales?
Old Feb 23, 2013 | 11:46 AM
jtaylortech3's Avatar
Question Crossfire Electric issues/Garage recommend Please - South Wales?
Hey there,
I was wondering if anyone could recommend a reasonable price/trustful garage that can fix issues with Chrysler crossfires in South Wales (based near Cwmbran/Newport). I am having issues with my Crossfire and it appear that its having an electronic fault to do with the transmission. I know there is a Chrysler in Cardiff but that is a bit further than I would like to go, also because money is very tight going directly to Chrysler is likely to be a very expensive option. Any advice would be welcome, Thanks.
Justin
Old Feb 24, 2013 | 02:48 AM
11 FEB's Avatar
Default Re: Crossfire Electric issues/Garage recommend Please - South Wales?
hi Justin.
post a bit more info about your problem you will probably get more response!
(I sound like an agony aunt) lol lol
Old Feb 24, 2013 | 12:12 PM
crossfire crossfire
Old Feb 24, 2013 | 01:38 PM
pct's Avatar
pct
It sounds like its going into limp mode Justin, the computer is detecting a problem and putting the car into 'get you home' mode.
It probably needs to go on the diagnostics gear to find the fault, but there may be a way of reading the codes yourself, someone on here might know how to get the car to show the fault codes via flashing lights on the dash for example.
Old Feb 24, 2013 | 02:03 PM
Originally Posted by jtaylortech3
Ok, well the issues I am having is that recently 3 warning lights came on which are the abs, bas esp and the handbrake light. They all come on at the same time and generally shortly after the light comes on the car won't move much if you press the accelerator (I would describe it as if your stuck in lower gear in a manual car). If I stop the car, turn the engine on and off, then try to go again all the light go off and it can drive for a while before the same issues happen again. Its a very strange thing and when its not doing these issues, it seems to drive perfect with no issue I could think of at all....
Hope that helps. Thanks
You need the fault codes read, the dash lights do not flash to tell you the troubles. You need to use an OBDll scanner. With the codes we can tell you the problem solution most likely.
Old Feb 26, 2013 | 05:09 PM
crossfire crossfire
Old Feb 28, 2013 | 07:12 PM
pct's Avatar
pct
Any updates on this Justin?
Old Mar 1, 2013 | 03:17 PM
crossfire crossfire
Old Mar 18, 2013 | 12:35 PM
Angry Re: Crossfire Electric issues/Garage recommend Please - South Wales?
crossfire crossfire
Old Mar 18, 2013 | 03:33 PM
pct's Avatar
pct
wondered how you were getting on with the problem mate, sounds like it might be worth a call to the breaker in the previous thread to see if you can grab a second hand ECU.
Old Mar 18, 2013 | 06:40 PM
crossfire crossfire
Old Mar 18, 2013 | 07:24 PM
texas t's Avatar
Smile Re: Crossfire Electric issues/Garage recommend Please - South Wales?
Is this what u need 2004 CHRYSLER CROSSFIRE 3.2L ECM order now 800-890-4012
Old Mar 18, 2013 | 07:39 PM
pct's Avatar
pct
Thanks for your reply mate, appreciate it and do you have a link to the breaker at all? Guessing he sells parts or has contacts that do? Yeah didn't think about that.....wonder if I could sort out one second hand and what cost would be, thing about crossfire thou is that they aren't exactly dime a dozen so not sure if they would be difficult to find (fingers crossed thou).
Justin
CHRYSLER Crossfire AUTO - Breaking Vehicles at Autoline Motors
Old Mar 19, 2013 | 07:15 AM
xfchris's Avatar
Welcome to ACD of LANCASHIRE - The UK's leading Chrysler and Jeep used parts breakers
try these people...many club members have bought off them they specialise in breaking chrysler vehicles..mention ukcrossfires and you might get a bit of discount as the club has had a couple of meets there...best of luck...chris
Old Mar 19, 2013 | 01:30 PM
crossfire crossfire
Old Mar 19, 2013 | 04:34 PM
Thanks for all the replies, much appreciated. After speaking to the garage its not what I thought it was but its actually the ABS control module that needs replacing they have said.
Thanks,
Justin
You had the car in limp mode, which is an indication of a transmission fault, you read the codes and it says transmission speed sensor fault and the garage says it has to do with the ABS brake system. Hmm!
I'd say you had better be careful with what is done here or they might take you for an expensive ride before your car is on the road again.
I have had this on a Chrysler 300 which has a very similar transmission and it was a faulty solenoid in the tranny. The car would work fine when it was restarted every time for a few days then the limp mode became permanent.
My money is on the speed sensor which is on the hydraulic/electrical plate assembly.
Old Mar 19, 2013 | 04:49 PM
crossfire crossfire
Old Mar 19, 2013 | 05:15 PM
pct's Avatar
pct
This does sound similar to a fault I had years ago with completely different car a Toyota MR2 Turbo import which was fitted with traction control.
Basically the ABS and traction control was all linked together on that vehicle and when the traction control came in it was supposed to brake the spinning wheel and cut power to the engine, mine had an intermittent fault causing the car to slow to a crawl and the more you tried to accelerate the more the brakes came on and the engine power cut back along with the illumination of various warning lights.
Its a long time ago now but i think that was traced to an ABS fault
Old Mar 19, 2013 | 05:59 PM
Thanks for your input but no it is defiantly nothing to do with the garage, this garage is one our family has used for over 20 years and they always do things as cheap as possible (saved as a fortune) so we are lucky to have them, unlike a lot of other garages which will rip you off (that's why we wanted it done there) but this one you can 100 percent know you can trust them!
The error code as I mentioned previously = speed sensor circuit malfunction so its not transmission fault and to be honest there is zero indication there is anything wrong the transmission as I have said previously the car works perfectly before the warning lights come on. And also couldn't be speed sensor as like I said that is the part they replaced recently (but didn't fix the issue) so I am sure it is definitely something to do with ABS malfunctioning and fact all the warning lights that come on are braking system related I think backs up that theory. Obviously could be several things in that category but anyway like I said in previous post, the garage is going to arrange to "borrow this part" from mercedes soon and fit it to my car and see if that does resolve the issue. If it does then its defiantly that and then I will just need to arrange to get the part for as cheap as possible! So just have to wait and see I guess...
The code you mention is definitely a transmission code and not a wheel speed code.
If a wheel speed sensor went on the blink then I could see the ABS/traction control stepping in to correct what it felt was a loss of grip in one wheel.
I guess its too late now but I would have thought that a rotor would have felt much hotter when compared to the rest of the rotors if it had been braking all the time or more often.
Other parts that can cause the ABS to operate when it should not be are the sensors that determine which way the car is facing and which way the car should be facing, acceleration monitors, yaw sensors and the like of which I have absolutely no idea about.
The code is for a faulty part inside the transmission.
The wheel speed indicator is something like this:
Attached Thumbnails Crossfire Electric issues/Garage recommend Please - South Wales?-abs_wheel_speed_sensor_06.15.11.png
Old May 3, 2013 | 09:57 PM
Unhappy Re: Crossfire Electric issues/Garage recommend Please - South Wales?
crossfire crossfire
