Clouds of oil smoke after 250 miles ?
Re: Clouds of oil smoke after 250 miles ?
Check your Pollution Control Valve. If it's stuck open, the car will be sucking oil into the cylinders through the MAF tube. If this is it, you'll need to replace the PCV and clean the MAF sensor. Not really a tough job, and the symptoms are much more serious in appearance than the actual problem is.
However, the M112 engine does not have a PCV valve, the left valve cover just has a tiny hole where the large tube connects prior to the throttle body, and another even smaller hole ( along with the right valve cover ) for the smaller hoses that connects post throttle body.
I once got the bright idea of removing and capping off the large hose - BAD IDEA.
The engine made some really strange noises that had me thinking bad water pump, although it continued to run OK.
I'm thinking maybe the OP has a burnt valve or something. He should do the dollar bill test ( or pound note test ) : with the car idling, slowly lower the bill down over the exhaust, if it sucks into the exhaust tip, then probably a burnt / sticking valve.
redsnake (07-23-2023)
Location: sandhurst UK..home of the royal military academy
on
1 Post
Normally good advise, John.
If before was it installed correctly?
I thought a catch can could cause this if it was filled to the max and needed emptying. See post seven.
Car has 92k on the clock and has oil catch tank fitted in large breather to try to cure the smoke fault to no avail
The LARGE single host connects from the driver side valve cover to the fitting BEFORE the throttle body.
https://www.crossfireforum.org/forum...re-oil-catch-c
Here's a thought : remove one or both of the valve covers ( the BIG ones, not the little vent ones ) - see if there is much gunk in there.
If this car has always had Mobil1, should be very clean, if not, then those very tiny holes in the vent covers where the small hoses connect could be plugged. They should NOT be 'dusty dry'.
My car at 52,000 miles : ( click the picture, then click 'enlarge' )
Any resolution to this issue? I've had it for some time and couldn't find anything. Same symptoms. After a few hours it just blows oil smoke out the back. Occasionally it will trigger a misfire code on a few cylinders. I just let it cool a bit an off I go like nothing happened. Occasionally it will do this after a number of shorter drives.
I have 153K on it, and am looking to get rid of the car, so I don't want to spend more money on this car after almost a $4k investment earlier this year just to get to work.
Thanks!
Thanks!
Thanks!
Thanks!
Have you overfilled with oil?
Look at the above post answer and see if that applies to you.
Fault with my car turned out to be cam box cover/breather area partially blocked with a carbon build up restricting the return flow of oil to the sump/oil pan so the breather was drawing oil into the throttle body/intake manifold , hence misfire and smoke cloud until oil in manifold cleared of oil.
Hope this is of some help , it took a back to basics approach!
