Brake Sensor
Old Apr 16, 2008 | 05:47 AM
CrossfireRoadster's Avatar
Default Brake Sensor
Does anyone know the part number for the Brake Pad Sensors for the 2005 N/A Crossfire Roadster? I called a few dealerships and they want the last 9 numbers of the Vin to look them up, unfortunately I didn't drive the Xfire to work.
Any help would be appreciated. Thank you.
Old Apr 16, 2008 | 11:07 AM
huudoo's Avatar
Default Re: Brake Sensor
check here
https://www.crossfireforum.org/forum...ad.php?t=13875
http://www.majormotorshotrods.com/_d...rts_Manual.pdf
Old Apr 16, 2008 | 11:20 AM
robby363's Avatar
Try this number
5098719AA or
5099878AA. I'm not sure if that's it or not though they should know when they look it up. Do you need the front or the back? This is for the front.
Old Apr 16, 2008 | 11:34 AM
robby363's Avatar
Originally Posted by robby363
Try this number 5098719AA or 5099878AA. I'm not sure if that's it or not though they should know when they look it up. Do you need the front or the back? This is for the front.
The back sensors are the same part number also.
Old Apr 16, 2008 | 11:45 AM
I am all set the garage that is going to change my rotors and brakes are getting them.
just got off the phone with the dealer and he told me there are different part numbers for each.
5099908AA Front Right
5099908AA Front Left
5099913AA Rear Right
5099912AA Rear Left
Old Apr 16, 2008 | 11:57 AM
robby363's Avatar
5099912AA Rear Left
Those numbers you just posted are for the abs sensors and about $97 bucks for each one. And there not the brake pad sensors. You might want to make sure they're replacing the right ones.
Old Apr 16, 2008 | 03:13 PM
peter02910's Avatar
That is why I am not going to that dealership, I am trusting my local garage for non warrenty work.
Even though the parts are made by Mercedes they have Chrysler numbers. So if you have the number for a part that you need for the Xfire and ask for it from a Mercedes Dealership they will not be able to look that part number.
Old Apr 16, 2008 | 04:16 PM
sowardcustoms's Avatar
The Brake Pad Wear Sensor Numbers Are Front And Rear Are The Same #5098719aa List For 40.00 Each Mercedes #a2025400634.....
Old Apr 16, 2008 | 06:25 PM
perfect thank you sowardcustoms
Old Apr 16, 2008 | 06:48 PM
no problem i own a crossfire and also work in the parts department of a chrysler dealer so i try to help out as much as possible.....
Old Apr 16, 2008 | 07:21 PM
they are $40 each? So I need $160 worth of sensors whenever I need to change my brake pads? I thought they we like $10 each.
Old Apr 16, 2008 | 07:37 PM
robby363's Avatar
I think this is the part you need. http://www.parts.com/oemcatalog/inde...eid=7&siteid=2
Old Apr 16, 2008 | 11:38 PM
im sorry for trying to help good luck to you.....
Old Apr 17, 2008 | 12:14 AM
ok let me clear things up you said you wanted the wear sensors that is what i looked up they were $40.00 each ok thats the actual sensor the part you want the actual part that wears out or rubs against the rotor the little coiled up wire with a plastic thing on the end the thing that plugs into the (sensor) ($40.00) is in fact part number 5099878aa is $5.85 each list price its all in what you ask for sorry for the confusion i try to help out as much as i can i have been selling chrysler parts for 12 years im not saying im perfect but i try.....
Old Apr 17, 2008 | 01:05 AM
robby363's Avatar
This pic will help explain it also. I think it's the way they list the parts sometimes that makes it confusing.
Old Apr 17, 2008 | 04:49 AM
peter02910's Avatar
Hi Sowardcustoms,
That is the part. I appreciate the follow up. I have to say it is people like you that make this Forum great. Thank you for your time and clarification. As you can tell I am not good with cars.
rampntlion
21
Feb 11, 2019 08:18 AM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
