Yes Or No
Old May 26, 2008 | 10:53 AM
Knghtrdrzn's Avatar
Default Yes Or No
Checkout these rims http://cgi.ebay.com/ebaymotors/ws/eB...3D7%26_fvi%3D1 will they directly bolt on without needing any spacers or anything. If I read correctly the offsets are the same as ours. But I would do a staggerd set up 19's front 20's in back. Please give me any feedback you might have. Thanks Alot
Old May 26, 2008 | 11:28 AM
maxcichon's Avatar
Question Re: Yes Or No
The question of offset is one I've asked recently and have had no response to.
I've seen on this forum both:
22 Rear / 35 Front
and
35 Rear / 35 Front.
I'm still waiting to see a definitive answer.
Old May 26, 2008 | 01:25 PM
Maxwell's Avatar
Default Re: Yes Or No
for offset, you don't want to go more than whats stock, because when you push the rim further out past the pivot axis, this puts more force on the wheel bearings and steering box, not a good thing for longevity. this is why wheel spacers are not a good idea for our car, it's not exactly heavy duty suspension. also slows down your response time when turning the wheels
I wouldn't recommend anything over 19", in fact your better off going to a 18" rim on all four corners for a performance stand point, those big wagon wheels will suck hp, and the tires are ver pricey at 19 and 20"
Old May 26, 2008 | 05:17 PM
tashspop's Avatar
22 Rear / 35 Front
and
35 Rear / 35 Front.
i got 35 for the rear and need spacers.
Old May 27, 2008 | 12:39 AM
jonnyangel04's Avatar
I am going to have to disagree with you on this one Maxwell, Which doesn't usually happen. As far as the wheels sucking up HP your right on but as far as how good a 19 look with a 20 in the rear, hell I will do it again. Looks so good lowered and if the offset is right looks even better. I went with a 19x8.5 in front and a 20x9.5 in the rear 30 mm offset front and 35 in rear. if I could do it again i would go 35 in front and 40 in the rear looks amazing check out my old crossfire in the gal.
Old May 27, 2008 | 09:20 AM
Knghtrdrzn's Avatar
Ok so the rims im looking to get are 32mm F/ 35mm R. And JonnyAngel04 you say you have a 30mm F/ 35mm R. So the rims I want would work with no problems? Would I need any spacers? Also the hub size is 66.6 would that fit our car?
Old May 27, 2008 | 09:34 AM
tashspop's Avatar
yes, hubs are 66.60mm
i'll warn everybody looking into new rims about this. my new rims had less debth for the lug bolts so inturn the lug bolts where too long. long story short, my spindle and bearing are getting replaced because the tire shop tried to drive the car with the lug bolts hanging up on the e brakes. inspect everything before moving the car.
Old May 27, 2008 | 10:13 AM
Knghtrdrzn's Avatar
Ok so the hub size is good...what about the offsets..will they also work with no hassle of having to get spacers?
Old May 27, 2008 | 01:50 PM
my first set up worked perfect with no rubbing with those offsets, BUT i had a 15 mm spacer in the rear just for looks, and it looked good. Like i said before I would go with a 40 in the rear if Im not backwards larger lip and pushed out more. I cant remember the girls name but it looked good
On the front the tag is missing but they are 19 x 8.5 I'm not sure what the offset is thought. I can talk to the tire dealer that put them on for me and get that info from them if you want.
The rear wheels say 20 x 105mdm the offset is +25. If you need any more info you can email me at this email or on crossfireforum my screen name is ChryslerGirl.
HERE I FOUND THE EMAIL I WAS backwards I would go 25 in the rear I think i found the photos on cardomain which lead me to myspace which lead me to an email which lead me here lol look her up.
Old May 28, 2008 | 05:46 AM
strupgolf's Avatar
Tashspop, when you say your lug nuts are too long on the back, is it hard to change them out for shorter ones. Thanks Opps, I meant lug BOLTS
Old May 28, 2008 | 07:17 AM
MMZ_TimeLord's Avatar
Better not have lug 'nuts'... they should be lug BOLTS!!!
Too long... That's what hack saws and dremels are for...
Old May 28, 2008 | 02:06 PM
woodlands1's Avatar
I have 32mm front and 35mm rear offsets and have no rubbing problems.
