Front Camber Bolts
Old Sep 5, 2008 | 07:56 AM
RAM82A1's Avatar
Default Front Camber Bolts
Getting ready to take her in for an alignment and will order the 5140876AA camber bolts from Chrysler just in case I need them. Does the 5140876AA part number come with one bolt or two? How many bolts do I need, two or four? The dealer was clueless on both counts. Thanks in advance.
Old Sep 22, 2008 | 03:55 PM
NeverEnough's Avatar
Default Re: Front Camber Bolts
I'd like to know the the answer to this as well. Are there any available for the rear?
Old Sep 28, 2008 | 06:26 PM
dyezak's Avatar
You need 4, and the way the rear suspension is designed there aren't any camber bolts for the rear.
Old Sep 28, 2008 | 08:06 PM
04Fire's Avatar
If they're clueless I hope your not going to get the alignment done there!
Old Sep 29, 2008 | 04:12 AM
Steve Hellums's Avatar
When I installed my Eibach Pro kit I ordered an eccentric camber bolt kit from Chrysler. There were only one bolt per side, after installed I took it in for an alignment & the front camber was pretty well right on the money. But the tow was way off - front & rear. I had also installed a K-MAC adjustable rear camber kit bushings. Here is the post I made asking questions myself :
https://www.crossfireforum.org/forum...hlight=springs
Old Feb 10, 2009 | 06:18 AM
rodimus's Avatar
So you need four of part number 5140876aa just for the rear??
Old Feb 10, 2009 | 10:46 AM
rodimus's Avatar
I'm not sure maybe some other forum members know??
Old Feb 10, 2009 | 12:38 PM
BrianBrave's Avatar
<--- Huge Horsepower
The 5140876AA (Chrysler Part #) - - 2023300118 (MB Part #) - - factory camber bolts are only for the front (one on each side) - you need the K-MAC kit for the rears.
Here is a link for the K-MAC Kit
https://www.crossfireforum.org/forum...49&postcount=2
Old Feb 10, 2009 | 01:06 PM
rodimus's Avatar
I read 2 for each side, so it is one then??
Now I'm confused
Old Feb 10, 2009 | 01:16 PM
BrianBrave's Avatar
Now I'm confused
Per Mercedes Benz - "It would depend on the severity of the alignment required - up to two bolts per side for severe damage"
Buy four and return what you don't need.
Old Feb 10, 2009 | 03:34 PM
rodimus's Avatar
Oh ok-
So if its off about a degree do you think one per side would do?
Old May 15, 2013 | 04:59 AM
FUBU's Avatar
So I guess, if more alignment is needed, can the garage then just easily slip out the old bolts and pop these new puppies in?
Old May 15, 2013 | 07:00 AM
Abaton6's Avatar
OK, Speaking as someone who has never done a front end alignment,...Why do the bolts need replacing? When I replaced the struts on my Wifes 07 Tribeca, I just marked them, and put them back.
Old May 15, 2013 | 11:23 AM
Airscape's Avatar
Camber is not adjustable with the standard bolts. The hole the bolt fits into is oblong (___). The stock bolt is solid and centered in the hole. (_O_) The adjustable bolt has a notch on one side. You can put the bolt in with the notch facing the middle or outside of the car. This pushes the whole arm in/out a bit depending on what you need. (O__) (__O) or at least this is how I convinced myself it was working when I installed mine.
55chevy
Jul 22, 2024 02:31 PM
UNDER PSI
Nov 1, 2015 09:39 PM
maxcichon
Sep 25, 2015 02:55 PM
Posimoto
Sep 13, 2015 06:13 PM
Vegaslegal
Sep 10, 2015 11:24 AM
