Odd Front Tire Wear: Advice?
Old Mar 19, 2009 | 11:35 AM
62thunderbird's Avatar
Default Odd Front Tire Wear: Advice?
My old OEM Conti's exhibited an odd wear pattern on the feft front only. They were cupping evenly across the tread at a slight angle. The cupping repeated approximately every 5" all around the tire. I had the alignment and balance checked and all was well. Figured it was a bad tire. (tread separation, etc.)
At 35000 I replaced the Contis with some F1 all seasons and after 5000 that same wear pattern is now showing up on the left front again. So it isn't the tire, so what could it be? Alignment checked today is OK, tire pressure and balance both OK, and the wheel is not bent per the alignment shop.
I feel no odd feedback in the steering wheel nor did I ever with the contis, so I am stumped. I am at work, so I can't post a pic, but will when I get home.
Any ideas?
Old Mar 19, 2009 | 12:54 PM
LantanaTX's Avatar
Default Re: Odd Front Tire Wear: Advice?
I recently got an alignment done and tried Goodyear auto care first. They said the rear camber was off and I knew that since I have a lowered car. They told me the front was fine. I was cupping all four tires so I didn't like the anser I got. I then installed a camber kit front and rear and took it to better shop that works mostly on road race cars. They found a loose wheel bearing on the right front and toe was out all the way around. They corrected everything and the car drives great and is not showing any wierd tire wear.
I would suggest you take it to another shop that will check the front bearings and all the ball jounts before checking the alignment.
Old Mar 19, 2009 | 11:26 PM
devilduck's Avatar
My 2004 Xfire is showing this wear pattern on the fronts only at 90k miles... did you find a solution to this problem?
Thanks
dd
Old Mar 20, 2009 | 12:23 AM
Mimi05SRT6's Avatar
Great advice!
Old Mar 20, 2009 | 04:26 AM
waldig's Avatar
Talking Re: Odd Front Tire Wear: Advice?
Please check the shocks as cupping is often due to bounce, rebound etc. Woody
Shock the suspension and see how it bounces back. Sit hard on fender and jump up to see if it goes up and then down.....should not . Woody
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
PimpDaddy
Sep 29, 2016 11:55 PM
Bayukbros
Jul 29, 2015 10:16 AM
tom2112
Jul 28, 2015 08:12 AM
