Is this possible?
Old Apr 1, 2009 | 02:47 AM
TaReGt's Avatar
Default Is this possible?
Bolt patern: 5x112 , Offset : ET45 front and ET50 back, With : 8.5 front and 9.5 back Diameter 19''
and tires 235/35/19 and 265/30/19? Is that possible to fit to Crossfire. Not an srt
Thank you
Old Apr 1, 2009 | 05:48 AM
maxcichon's Avatar
Default Re: Is this possible?
Thank you
Fronts are OK with a 10 mm spacer and longer lugs.
Rears will require a 33 mm spacer to bring them back out to OEM center and way longer lugs..
That's kind of a thick spacer.
I WILL work, but will be a bit too weak for my tastes.
Old Apr 1, 2009 | 07:36 AM
TaReGt's Avatar
What about ET32 Front and ET35 Rear?
Old Apr 1, 2009 | 07:42 AM
MisterTaz's Avatar
Code:
TaReGt
32 ET should be fine with no spacers needed. The rears a 15mm hub-centric spacer will work. There are quite a few folks running that size spacer in the rear. Just make sure it is hub-centric.
Stay safe...
Respectfully,
Paul (MisterTaz)
Old Apr 1, 2009 | 02:17 PM
TaReGt's Avatar
What is hub-centric?
Old Apr 1, 2009 | 02:23 PM
maxcichon's Avatar
http://www.ezaccessory.com/Billet_Hu...es_p/5112m.htm
If you look at the photo, you can see a raised lip. This engages the inside diameter of the center hole in the wheel, forcing it to stay centered. "Hub" is what it uses as a reference and Centric" for what it does.
The center hole is a close fit on the hub-just like the wheel is.
Old Apr 2, 2009 | 06:53 AM
if the rear wheel has about a 3" lip then yes they will fit. you see the 20 offset (stock) with ) lip keeps the tire even with the finder,, now with a 3" lip with 45 to 50 offset that brings the tire back even with the fender,
and so and so on ( the larger the offset the more lip you need. ) also try fit the rim all shops will let u do that. jim
Old Apr 18, 2009 | 07:28 PM
kenyonmjr6's Avatar
if you want to get a set of 18x8 19x8.5 rims what offset do you need to get.
Old Apr 19, 2009 | 03:08 PM
MikeR's Avatar
Stock offsets would be fine....ET35 front.....ET20 rear...
I really want a set of the TSW Vairano's....why did you have to post them??
Old Apr 19, 2009 | 03:30 PM
kenyonmjr6's Avatar
I have an eye for potential. I ordered mine monday hoping to have them by friday.
