Crossfire brake pedal is not firm and slips down toward floor
Re: Crossfire brake pedal is not firm and slips down toward floor
Originally Posted by Atlanta_kid
#5, the dealer work-order says gasket and the hose test that I was told to do (see earlier posts) was was pointing at the leak right at #5 area.
Any vacuum in that area would suck any leaking fluid into the power booster.
I suspect the bushing that the vacuum line from the manifold plugs into was missing or faulty.
I have no experience in this area but I would have thought that O-ring was just to keep the dust out and fluid leaks in.
At the dealer when they pulled out the vacuum line off of the booster and plugged it with their thumb the hissing sound stopped so the leak was not on the line but was on the master cylinder/booster unit, the garden hose test that someone told me to try earlier in these posts, is a great tool to pinpoint the leak, I could certainly hear the hissing noise right around the O-ring area where the master cylinder sat on booster, I think the ORING keeps the vacuum up and also makes sure the booster stays clean of fluid or debris.
There are special brake seals designed for this dynamic application.
Remember lives depend on these seals, so only the most suitable design are used.
Thanks for the quick response I was looking at the drawing and it says o ring, safety is paramount and they are not the most expensive part. Have you ever done any work on the issue of bas esp light coming on. The brakes have always seemed a bit mushy.
please fully explain your problem.
You can move the hose around and listen to all the connecting points for vacuum hoses, you will hear the hiss get louder if there are any leaks. I have attached the picture to this post and the o-ring in my case was #5
My original issue was due to bad master cylinder but when the Chrysler tech replaced it he forgot to use the o-ring, and that caused me to lose my power brakes, so once I got that repaired the power brakes worked fine.
mhajek18
110
09-06-2019 01:04 PM
vspuds
10-11-2018 05:16 PM
wbaker1970
06-17-2015 08:57 PM
WindRestrictor
06-01-2015 02:31 PM
