Posi-Quiet Ceramic pad set?
Old 01-26-2012, 09:47 AM
Question Posi-Quiet Ceramic pad set?
... Deleted ...
Old 01-26-2012, 10:17 AM
Default Re: Posi-Quiet Ceramic pad set?
I used Posi Quiet on the front, part number 105.07400 for a NA. So far excellent results. I am not sure about price, check around.
James
Old 01-26-2012, 10:31 AM
Hey guys, is this ( Chrysler Crossfire 04 05 06 07 08 F&R Ceramic Brake Pads | eBay ) the brake pad set for the XF (front and rear) that will be the best for dust-free wheels? I keep seeing a lot of 'dust free' ads online and want to make sure I get pretty good (and quiet) ones. Also, is this price a good deal for the complete set? Thanks!
Freakingfast SRT6 sells these pads, PM him. He sells complete kits, but does individual parts. His thread is up today.
https://www.crossfireforum.org/forum...tml#post568047
Old 01-26-2012, 02:45 PM
PAULW's Avatar
I have the Posi-Quiet on the front only and there is NO dust and NO noise. I gave about $40.00 for the front kit a while back so $90.00 doesn't sound bad for both. I feel sure you will be happy with the product and you will be very happy you no longer have all that "DUST" to clean off your wheels
Old 01-26-2012, 04:53 PM
... Deleted ...
Old 01-26-2012, 04:56 PM
Probably the easiest brake job you will ever do. James
Here are a few pics with some info for the front https://www.crossfireforum.org/galle...y.php?cat=2031
Old 01-26-2012, 05:16 PM
... Deleted ...
Old 01-26-2012, 05:46 PM
To give you an idea of the ease of the brake job(and keep in mind I've done brakes before on a couple different cars)...
BillF and myself got the posi-quiets as well as new rotors. We picked last weekend to work on both of our cars..
Saturday started around 1pm ended around 6pm.. we were able to get 3 of the 4 wheels of BillF's car done in that time frame.. that included changing the rotors as well.
On Sunday we started at about 12:30pm.. finished not only his car but also all 4 wheels on mine(brakes and rotors) by 4:00pm. Now keep in mind.. we had to actually take the calipers and the rotors off.. so all and all not too shabby.
The front's are nice if you aren't taking the rotors off.. you can simply slip out the middle part of the caliper that holds the pads and slip in new pads.. and off you go.
Also we went the route of opening the bleeder screw right there at the calipers when compressing down the piston, to make sure we wouldn't be putting any pressure back on the pump. Also I usually recommend bleeding the brakes just a little bit to make sure you get any air that slips in there during the process..you will enjoy the pedal feel much more afterwards.
Old 01-27-2012, 02:27 PM
Mike-in-Orange's Avatar
I installed the Posi-Quiet Ceramics on my car with just 2500 miles on the clock and haven't looked back. Almost zero dust and not the slightest hint of a squeak. Still plenty of stopping power, even on track.
As others have mentioned, install was a snap.
Old 01-27-2012, 03:20 PM
JHM2K's Avatar
I may have to look into these, although I will need front pads for the 4-pot Mercedes Brembo calipers... OEM SRT-6 for the rears.
Price is right, and with Mike's glowing review, I may have to consider them.
Old 01-27-2012, 07:20 PM
... Deleted ...
Old 02-02-2012, 08:20 PM
... Deleted ...
Old 02-02-2012, 09:44 PM
Anyway, these pads have shims on them which they say eliminates the squealing on the brakes, should I go ahead and use that anti-squeal coating I bought?
General speaking, you don't have to use compound with the shims installed. I didn't on my Crossfire and no trouble. James
Old 02-02-2012, 09:53 PM
... Deleted ...
Old 02-02-2012, 10:28 PM
I went ahead and sprayed the anti squeal coating on the back of all four of mine prior to install. Haven't heard a single peep out of 'em since they went in. Was it really necessary? Maybe not, but it sure didn't hurt and it only cost a few bucks for the can, so.............
Old 02-02-2012, 10:37 PM
Heya James1549! Thanks for the advice on the squeal grease. I'll go ahead and install without and return the stuff (Back a few years, they were only $.99 per pack... Now they are $1.99 per pack and they sold me 4 packs)!
Brake job in the AM here! Will post results sometime in the afternoon!
Let us know how the pedal feel is. I have Akebonos and the pedal goes down more than I like and would have expected, they stop great and there is no leaks or anything. Some say that it is normal, but I remain skeptical.
I like the no dust side of it though, I did 1,500 miles and there was no discernible dust, some there but it was not really visible. Just a light dust was visible if you wiped your finger on the wheel.
Old 02-03-2012, 01:27 PM
That pedal feel is interesting, onehundred80. I did not experience of it with the Posi-Quiets on my Crossfire, but when I put the same pads on my daily driver it was downright scary. I did a full bleed on the brakes twice trying to correct it, to no avail. The damn car wouldn't stop, either. I had them on for a matter of days before pulling 'em off and putting a fresh set of Hawk HPS pads on that car (which are what were in need of replacement when I put the Posi-Quiets on that car).
I'm not enough a brake guru to understand why these pads are so good on one car (the Crossfire) but worthless on another (PT Cruiser Turbo) but I wonder if some bits and pieces don't play as well together as others do, possibly accounting for your situation with the Akebonos. Obviously not as bad a situation as I had with PQs on the PT, but still. The PQs on the Crossfire feel perfectly normal and stop the car beautifully (outbraking that Porsche 911 on track at California Speedway from 125mph).
Old 02-03-2012, 01:48 PM
Thirteendog's Avatar
i had the same experience with the SRT I had. You get use to them and adapt, but it wasn't something i liked.
Old 02-03-2012, 03:02 PM
I drove it from Florida for 1,500 miles with my son and I got used to the feel but I always like to know why and I have not had an explanation. The pedal goes down 2" more than normal, weird. I will replace them soon I think.
Ideas?
Old 02-03-2012, 03:38 PM
JHM2K's Avatar
Ideas?
Hawk HPS is by far the best pad I've ever used. Not as clean as the Akebono pads, but MUCH cleaner than the stockers, and the braking power is quite strong for a street-rated pad. Akebono's single claim to fame is dust-free... Hawk has been a staple in the SCCA for years.
Quick Reply: Posi-Quiet Ceramic pad set?
