Skinnies arrived today
Old Nov 4, 2013 | 10:27 PM
grip grip's Avatar
Default Skinnies arrived today
I received the skinnies I bought from daithi2 (Harvey) today, and they will work with the big brakes as long as I'm running some spacers. The weight savings is 20lbs per wheel/tire combo. Hopefulley these will be good for a tenth or so.
Current front tire versus the skinnie
Rear drag radial and front skinnie
Weight of current front wheel/tire
Weight of skinnie wheel/tire
Old Nov 5, 2013 | 11:31 AM
Default Re: Skinnies arrived today
Nice weight savings, that rotational weight loss will be good for some time, for sure.
Looks silly to see those beautiful brakes behind that donut looking wheel, but function over form at the track....
Old Nov 5, 2013 | 11:36 AM
sk8erjosh09's Avatar
Awesome, can't wait to hear what happens your next time out.
Old Nov 5, 2013 | 12:34 PM
no that's racin'....but I can't bring myself to do it....lol.... The ole' Camaro had 10" cragers in the rear, and 3" cragers in the front and looked good... I guess I like to show and as much as I like to go...lol
Old Nov 5, 2013 | 12:49 PM
velociabstract's Avatar
Planning on lifting the fronts? I want some shots hooking off the line.
Les
Old Nov 5, 2013 | 04:21 PM
JHM2K's Avatar
Didn't the skinnies actually COST you time when you ran Steve's?
Old Nov 5, 2013 | 05:30 PM
Holycrap's Avatar
There's some member on here that used skinnys and got an incredible time on intake/tune/pulley. I want to say he was using a 185 and ran a 11.6 or 11.7. So yea, count on the decreased contact patch and weight savings to definitely shave off time.
Old Nov 5, 2013 | 06:40 PM
grip grip's Avatar
They certainly are fugly.
I'd be happy with a tenth.
If they lower my ET's, I'll paint them silver so they aren't so hideous.
Les
That won't be happening for me unless I build the engine for a 400 shot.
Yes, but I think his were anchors.
I'll find out in the Spring. I've got too much noise from the new carrier to beat on it anymore this season.
Old Nov 5, 2013 | 07:29 PM
yes, Moparrbust ran skinny set up, with great runs... Keep us posted on the rear issues..already looking for parts for a swap on mine...been wanting to do this from day one..
Old Nov 5, 2013 | 07:32 PM
At least it wasn't me that said Steve's skinnies and slower in the same sentence.
Les
Old Nov 5, 2013 | 07:34 PM
Does D/A affect the skinnies? Haha, Cruizinquick joke. (It's ok, I'm leaving the country for a couple of weeks ….. vacation)
Les
Les
For a guy who lives in the tropics, you sure like thin ice.....lol
Old Nov 6, 2013 | 12:59 AM
dinasrt's Avatar
Les
I kind of miss that Cruzinquick. As a newbie on here awhile back, I asked about how to remove those OEM crimped hose clamps on our stock intake system, and I got ridiculed by none other than Steve! It was Cruzinquick that came to my defense.
I hope those lighter skinnies get you your 1/10th Anthony.
Old Nov 6, 2013 | 04:33 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ its just gotten a lot easier to clean those front wheel wells...
Old Nov 6, 2013 | 06:05 AM
I grew up with lots of brothers so I can be a sarcastic jerk sometimes but the truth is I miss both Steve and Cruzin, a lot. Steve because he tells it like he sees it and he only sees things 2 ways. Black and white with no grey areas. Cruzin was the same. We need diversity to keep it interesting. (Olive branch)
Grip ends up with most of my dream parts and documents the results. I'm looking forward to the skinnies being beautified as they surely will be.
Les
Old Nov 6, 2013 | 08:28 AM
I know...just razin' you... I pull no punches with Steve...he's knows I like to jerk his chain... I am sure Anthony will dress up the fronts this winter... I use another ole' drag racin' trick for my fronts, but it doesn't help with weight... now to find some gearing...lol
Old Nov 16, 2013 | 10:46 PM
grip grip's Avatar
I added 10mm spacers and went for a test drive today with the skinnies. For the record, they are 17" wheels from a e500 and tires are M&H Racemasters 4.5-26x17 DOT's. I realize they are hideous, but I plan on powder coating them silver over the winter.
Old Nov 16, 2013 | 10:50 PM
JesseJamessrt6's Avatar
silver would be good. A setup like this means it isn't your first rodeo. Have you adjusted your konis just to see if there is any difference?
Old Nov 16, 2013 | 11:26 PM
grip grip's Avatar
I'm running stock shocks and springs until Hustler's kit is released.
Old Nov 17, 2013 | 07:39 AM
32krazy!'s Avatar
skinnies that weigh 51 lbs and you call the CCW skinnies i had boat anchors!! HA! for the record les i have been slow all yr long. best i could muster was 11.6 @ 123 mph. the winter engine build should fix that by 15 mph at least. looking at 700 rwhp by spring
