spring pads
Can someone please tell what spring pads I should get to make my car lowest it can be. Current setup eibach springs, kyb shocks, & 19x8 and 19x9.5 mandrus millenium. Thanks
Re: spring pads
Re: spring pads
careful with this mod as it will prob require camber kit if you don't have one already.
Re: spring pads
The lowest is the number 1 Burl. If you currently have 5 burl it will lower it abour another 1/2.
Re: spring pads
quick question... If you like the height of the car, but you plan to switch out shocks and springs, at which point would you replace the spring pad or are they good for ever?
I have already done the springs, so obviously I wanted the car lower, but its good now, scrubs only when backing up and turning. Im getting ready to have shocks put in and want to have it all right once it gets buttoned up. Anything else I should do when im down there, arms, ball joints etc. 138K on this car. Runs like a dream! but some vibrations around 55-65mph. (balanced 3 x already) |
Re: spring pads
I say they are practically for ever.
Re: spring pads
Originally Posted by mobilefitt
(Post 792298)
Re: spring pads
Originally Posted by FP
(Post 792299)
Re: spring pads
(Post 792305)
/....................... Runs like a dream! but some vibrations around 55-65mph. (balanced 3 x already)
Re: spring pads
1 Attachment(s)
I have a similar set up. Currently, I am scrubbing the inner fender on both sides with stock spring pads. I think a slightly thicker pad up front may help.
I have stock wheels currently and I was wondering if anyone else has had this experience? I'm thinking another 2 or 3 mm's would fix this. |
