TPMS 101, The Basics.
Re: TPMS 101, The Basics.
In all reality we cannot deduce same ID's nor can we deduce the system is working correctly from just swapping a set of wheels/tires and not get a light.
Naturally a light will now come on in the next few months.
Edit
Actually the light came on in June 2020.
I think that the title of this thread is misleading... it went around in circles & basically ended with “it is what it is.”
When I take my 2005 to Discount Tire, what Schrader TPMS sensor can they install that will actually work? They installed some a year ago on my rear tires that never worked. I called my local Chrysler dealer and they said that they would try to program them, but, it would cost $100 an hour to “try”...
ZH SRT (Clint) worked for Chrysler and is the one with inside knowledge, listen to him.
Read post #54 and all will be revealed.
Search 33500 and you will find people who have had these fitted and are working. The actual part to use is #33700 it has the aluminum stem, 33500 has the rubber stem.
ReliableRon is one person I can think of.
Brian P (10-17-2020)
To me the simplest way to replace TPMS is to do it while the tires are already off for other reasons. I replaced mine at the tire shop with the OEM style that Schrader makes then I drove to the dealer who charges me 1/4 hour to sync them. I already had the plan and knew the dealer charges before going to the tire shop.
I wasn’t trying to be critical of this post and I apologize if it came across that way. I already replaced two tires using the TPMS replacements that DT suggested & they didn’t work. I appreciate you confirming what the true answer is. I’ll be happy to work with them with this information.
on
Old school works BEST and is only about a dollar or so every three to four years. Its called a Tire Pressure Gauge, SURPRISE! Then when your used to doing it the old fashioned way (AND/OR) are changing tires, use the old fashioned rubber valve stems (I suggest the shortest ones you can find so they don't get chopped off on curb rubs), those are pretty inexpensive as well. Finally, bypass that POS of a TPMS ASAP and be DONE WITH IT... Saves a lot o headaches and MONEY...
Brian P (10-18-2020)
Okay, so, I had my front tires replaced yesterday (it’s running great). I had the technician replace all of the TPMS sensors and install Schrader 33700. It took a few tries to get him to understand, but, he finally agreed to do it. I explained that he had to know the frequency from one of the front tire sensors. He installed them, used his tool and told me that they all were working at the 433 frequency (he looked up the VIN instead). He gave me the standard, “you have to drive it for it to sync to the TPMS.” I drove it 8 to 12 miles and the light is still on. At what point do I declare it a failure and take the car back to check the frequency, etc.,? Note that he did give me the old sensors, I’m not sure why. 🤷♂️😄 I will manually verify that the tire pressures are correct before I take it back. Thanks!
Okay, so, I had my front tires replaced yesterday (it’s running great). I had the technician replace all of the TPMS sensors and install Schrader 37000. It took a few tries to get him to understand, but, he finally agreed to do it. I explained that he had to know the frequency from one of the front tire sensors. He installed them, used his tool and told me that they all were working at the 433 frequency (he looked up the VIN instead). He gave me the standard, “you have to drive it for it to sync to the TPMS.” I drove it 8 to 12 miles and the light is still on. At what point do I declare it a failure and take the car back to check the frequency, etc.,? Note that he did give me the old sensors, I’m not sure why. 🤷♂️😄 I will manually verify that the tire pressures are correct before I take it back. Thanks!
About a year back, I replaced the PS sensors on my 2007 Coupe with VDO REDI-Sensors. Discount Tire performed the work. They were able to scan the wheel sensors to tell which ones were bad and triggered the warning light. But Discount Tire was unable to go thru the TPMS "relearn process" with the scanner tool they used. (Note: They actually didn't charge me anything for the new REDI-Sensor they provided (I provided the other one) and the install because they couldn't complete the "relearn process".) So I bought the DRB3 Emulator software et al and performed the "relearn process" myself. I've got the VDO REDI-Sensors for the DS whenever I need to replace them. I've also used the DRB3 Emulator software to perform the "relearn process" on another XFire Owner's car after he had all the wheel sensors replaced. Takes only about 20-30 minutes
There is another thread that discusses the DRB3 Emulator software and how it is used, along with wheel scanner tools that are compatible.
Only a DRBIII (or equivalent) can place the car computer into learn mode.
lovecross (12-01-2020)
If this were my car I would take all of the old sensors to him and have him read them. He may need a huge speaker magnet to trigger them. Once they do that you will know for sure if what was put on is the correct freq. Now that you know the freq. and if the correct parts were put on you can have any dealer with the DRBIII or emulator sync the new sensors. Now here is the caveat, I know nothing about the part number you posted. I used 20028 on my car. (Now replace with the 20096) See https://www.crossfireforum.org/forum...tml#post830633 Post about my TPMS with DRBIII
This page was posted for our cars... TPMS spec page And this info I just see today... updated Schrader part number 20096
I CANNOT FIND A 37000 ON THE SCHRADER WEB PAGE
This is very simple, I've done it twice and it works like a charm.
What ever sensor you have in there in inconsequential as long correct for the car regarding its specifications, the brand does not matter.
After any new sensors are installed (Cloned ID or not) the system must be reprogrammed using a DRBIII tool which usually means a Chrysler dealership.
That’s it, there is simply no way around that.
No matter what you else, the Mechanic, the shop, the manager, the guy who changed the tire, anybody, thinks it just doesn’t matter.
That includes any number of unfounded theories in this very thread. Everybody thinks, and tries to find, an alternate procedure, and there simply is none.
I’ll double check with DT. I did say Schrader 37000 TPMS sensors (based on a separate thread) and they knew the ones that I meant. They used their tools and said that they were working, but, I didn’t confirm that they managed to put the computer into learn mode. I’m about ready to order my own tool and be done. I called multiple Chrysler dealers last year and the best that I could get was that they’d charge me $100 to try... 🤷♂️🤦♂️
Some have tried their own WIN7 software routes but there are a ton of "I can't get it to load, install, talk to the car" posts about that.
