Lowest Aftermarket Springs?
Okay, so after searching here and online, I'm not finding a definite answer to my question, which spring will drop my crossfire the most? Getting the camber bars from Ground Control and the camber bolts for the front so I am good to go (Or at least I hope!) on that front. I really don't care how low the car sits, I just want to get ride of the 2 inch wheel well gap in there rear.
Also while I am asking questions, can some one shed some light on the spring pads? in the past on cars that I have lowered, I have taken these out completely sometimes and would slide a piece of rubber hose on the last coil to keep the noise down. I seen a variety of pad sizes on needswings.com, if I want the lowest drop possible do I just order the thinnest pads? or would the rubber hose trick work? Thanks in advance. |
Re: Lowest Aftermarked Springs?
No One out there lowered their car?
I would recommend that you cut your springs by 1/4 of a circle at a time and no more than 1/2 a circle. This will give you aprox. 1.5" drop. Any more than that and the ride becomes too harsh and unplaisant. If you want to drop more and are on a budget, you can shave the pillow blocks. I like the slipping a hose over the coil spring idea. However, I doubt this would be a long term solution
My Eibachs lowered the rear ~ 2.5" and the front 1.5".
After break-in, of course. Oh-and 3-dot spring pads front and 5-dot rear. It's lowered MUCH more than Eibach advertises. |
(Post 841041)
(Post 841052)
That's without Austin in the car with you ;)
I have a complaint in @ Eibach. We'll see.:rolleyes: |
Your best option would probably be getting the ground control springs and getting the lowest spring pads possible. I think there was a company called B&G that made a kit that was 1.8" .
1 Attachment(s)
I'm on slightly tweaked KW V2 coilovers. They don't normally go this low....lol. And for the love of god don't cut your springs. It's not an 80's Honda.
Attachment 40053 |
(Post 841327)
Yep. Sans Austin. Full tank of 93, though!
Re: Lowest Aftermarket Springs?
Anyone want to buy a new set of Eibach's?
Does anyone know how much just the ground control springs lower your car inch wise? Their website does not give any details. I am trying to decide what springs to buy.
(Post 841041)
12 weeks or so....
