Is $600 a rip off to pull the rear subframe?
My 2005 Crossfire base is making a clunk noise when I accelerate moderate to high especially in first and second gear and this auto shop says it would cost $600 to pull the rear subframe, he said quote "To mount on the rear cradle $116 each but it would cost $600 to pull the cradle down." My friend says it's a rip off, I'm not an expert on cars, so I was wondering if anyone knows or has any experience with that?
Re: Is $600 a rip off to pull the rear subframe?
Did he indicate exactly what was making the clunking sound? You may have a sway bar bracket that has torn itself from the body. Pretty common I'm afraid and requires some welding to usually fix.
Originally Posted by syfi
(Post 843773)
Make sure you have those rear subframe bushings in hand before doing anything. I believe they're hard to come by. It sounds high to me but I'm cheap and would likely attempt to do it myself.
Les |
Originally Posted by velociabstract
(Post 844478)
Les |
if U want to do it your self ... click on the arrows
https://www.crossfireforum.org/forum...installed.html |
