Bas light new tie rod assembly
Old Jul 21, 2016 | 09:42 PM
Caleb's Avatar
Default Bas light new tie rod assembly
Just replaced all four shocks and the tie rod assembly. I got the length of the new tie rod assembly to match the old one and now the steering wheel is turned almost 90 degrees to the right for the car to go in a straight line and the bas esp lights are on when I get to second gear as well as the traction control light. The car has supposedly been aligned the best they could. Any ideas?
Old Jul 22, 2016 | 10:52 AM
ZX2 Nick's Avatar
Default Re: Bas light new tie rod assembly
If you matched the new tie rod length to the old one there is no way in hell the steering wheel would be more than a few degrees off.
Old Jul 22, 2016 | 10:54 AM
Caleb's Avatar
My thoughts exactly. No idea what is going on. Just made an appointment for Tuesday to get it looked at. Hopefully they can figure it out.
Old Jul 22, 2016 | 11:11 AM
How far was this taken apart? If the pitman arm was disconnected then it could have been put back together with the wrong spline alignment and if the steering wheel is not aligned the BAS light will come on as it is not set correctly. The sensor is in the steering column.
Old Jul 22, 2016 | 11:14 AM
Caleb's Avatar
Pitman arm was not removed. Just pulled the tie rods from both steering knuckles and pitman and idler arm but nothing other than the old tie rod assembly was removed and now the steering wheel is very far to The right. I thought the same thing about the Pitman arm but I can't see how that would be the case
Old Oct 14, 2016 | 10:58 PM
ShawnQ's Avatar
Did you figure this out? I'll be replacing the linkage on my car soon, and I'm researching potential issues. Any input is appreciated!
Old Oct 14, 2016 | 11:01 PM
Caleb's Avatar
I just replaced the tie rod assembly then got it aligned and all the lights went off and steering wheel is straight once again. An out of line front end will make your crossfire act crazy!
davidf30
Feb 19, 2020 10:00 PM
mmann
Apr 9, 2016 10:05 PM
kstewart
17
Mar 30, 2016 04:48 PM
leaddog2015
Mar 1, 2016 04:58 PM
Alfred107
Jan 6, 2016 10:19 AM
