Brake Noise
Old Mar 11, 2005 | 10:57 AM
azonie's Avatar
Unhappy Brake Noise
Has anyone else experienced a loud brake squeal. It only happens every so often. It sounds like brakes when they are starting to ride on the wear indicator. But I understand the Crossfire doesn't even have such indicators.
I have found that if I just pull the emerg. brake handle up to point of alarm (no pad contact) it will stop.
Old Mar 11, 2005 | 11:11 AM
mbepic's Avatar
Default Re: Brake Noise
It would help if we knew where the squeal from coming from, front or back brakes.
Does it only happen when you apply brakes?
Do you use your emergency brake a lot?
From your comment about emerg. brake handle, you must think that the squeal is related to back brake, specifically emerg. brake.??? How many miles do you have on car?
Old Mar 12, 2005 | 03:21 PM
andrew's Avatar
-C-I-C-C-I Associate Member
probably just a small stone b/t the pad & rotor. it will work its way out. but...some pads just squeal every so often.
Old Mar 13, 2005 | 11:46 PM
azonie's Avatar
I think the noise does come from the back and its only when the brake is not being applied. When you press on the brakes it stops. Just like it would if it were the wear indicators. It is my understanding this car does not have metal wear indicators.
My car only has 3,000 miles on it. Has done this off and on from beginning.
Old Mar 14, 2005 | 09:09 AM
Dan Root's Avatar
Banned
Sounds like dirt, try running your xf at about 150mph and stopping before a CHP sees you !
Old Mar 14, 2005 | 10:50 AM
NJspeed69's Avatar
Well how many miles do you have so far? I thought all modern cars brakepads have those wear indicators..
Old Mar 15, 2005 | 06:42 AM
Speccy's Avatar
If its a stone logged in the pad. The best way I have found of getting them out, short of removing the pads. Is to reverse at about 4-6mph and give the brake peddle a short sharp stamp. So that you do not come to a stop. Usually gets them.
Old Mar 15, 2005 | 08:14 PM
roms33's Avatar
If you are doing a lot of fast driving and brake hard on the highway you will end up with sqweeky brakes.
ty_ty37
Jun 27, 2024 10:42 AM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
