Tire size question?
Tire size question?
I知 going 18x8.5 front with 225/40-18s but in the rear is where I知 going back and forth..... I知 going with 19x10 +25 and I知 wondering if I should go with a 275/35-19, 285/30-19 or 295/30-19??? I am lowered on Eibach/KYB set up with rear adjustable camber arms. Any help would be appreciated. Thank yoj
Re: Tire size question?
I have esr sr08
Front 18x8.5 +30, Yokohama avid
Rear 19x10.5 +22 michelin A/S ZP 285/35
Stock height, after I removed a screw on front clearance is good, on back I have some light rub inside and close on outside, check my thread 19x10 19x10.5 for pics of clearance and the rub mark.
If I roll the fenders some then I can adjust my camber arms out.
There are some that use a +25 do not remember the size the tire wheel they use or if lowered.
I have esr sr08
No rub is the only acceptable condition!
as like I said in my thread, the rub was from when I shoved my tire into the fenders, drove front drivers tire on a big pile of ballast and had all the weight on 2 tires and 2 tires off the ground, was checking clearances about a year ago.
As seen in the pictures.....
do you think I would risk blowing a tire 4 hours from my house ?
the rub is from the corner of the tread when it was shoved as far as it can go in fender.
62thunderbird
06-24-2007 05:14 PM
