Vendors - Suspension
Old Jan 21, 2021 | 03:24 PM
am4017's Avatar
Question Vendors - Suspension
Hey yall, I started to notice my car pull a little to the left and sure enough, the lower control arm bushings are starting to go. I have looked everywhere for them and cant find a good brand or ones that I would trust, Anyone have any suggestions on where to look for some?
Old Jan 21, 2021 | 03:40 PM
Bill F's Avatar
Default
See post below for Control Arm Bushing
Old Jan 21, 2021 | 03:42 PM
Bill F's Avatar
Default Re: Vendors- Suspension
.https://www.google.com/search?q=cont...hrome&ie=UTF-8
Old Jan 21, 2021 | 04:04 PM
Ronman's Avatar
It is cheaper to usually just replace the entire lower control arms instead of having someone try to press in new bushings. I just bought some lower control arms from Rockauto.com, LEMFÖRDER 1347801 and LEMFÖRDER 1347901. There is a discount code for 5% off you can use at Rockauto. You might want to change the center link too, I did that and ball joints.
Old Jan 21, 2021 | 04:23 PM
green24u's Avatar
Check out FCP EURO also for price comparison. FCP carries OEM Lemforder also.
Old Jan 21, 2021 | 09:10 PM
Toolman's Avatar
Been there and done that. Replaced my rear control arm bushings with KMAC adjustable bushings to fix an alignment issue. The KMAC including "bolt" bushing extractor did not work. I had to use a press. Consider the cost and time to have someone press the old ones out and new ones in.
DSCN09531
Valk
Feb 23, 2017 11:43 PM
curtisr
27
Nov 27, 2016 07:38 PM
Valk
May 19, 2013 04:44 PM
LugNut
Sep 16, 2009 04:58 PM
Dan Root
Aug 7, 2004 09:59 AM
