i do not see how it would hurt the belt either but i will see what i can find.
on the extra pulley you bolted on, without going outside again (im lazy lol) is there a stock pulley there or is there just an empty bolt hole that you stuck the spare pulley on?
also, you have the much smaller than stock idler pulley since you have the crank pulley so i assume the code3 guys will need to buy 2 pulleys (which is no big deal) to do this mod or the belt will rub up against itself due to the larger idler pulley
Thanks
Originally Posted by tighed1
Hope you can find a part number to put folks minds at ease. Some will worry bout the ribs hurting the belt. So far I have not seen any wear.
I went through every pulley box at the local Autozone and could not find a similar smooth pulley.
