Front license poll: yes or no?
My car came with the front plate bracket in the back hatch, knowingly, they will have to DRILL into the front bumper where there are no holes or guides to mount the front plate = yikes!!! What if they drill them crooked??? What have you done = front plate or no front plate???
Re: Front license poll: yes or no?
My state (VA) requires a front plate. No choice in the matter. If TX law requires a front plate, I guess you can take your chances by not installing the bracket (pleading "there's nowhere to put a front plate") and hope a cop doesn't cite you anyway.
Mine is on straight. In fact mine was placed correctly - I have seen to many mounted too high up and not below the bend where it should be. I took it off and put some plugs in to get some estimates when I bought it to fill in the holes and paint them... After two estimates, (about a week with plugs) I got pulled over for no front plate...
In texas I believe you can stick them in the front window (I think it states it has to be able to be seen from the front of the vechile - not attached to the front, but not postive). The problem is that as curved as our windshield is, it does not work well and may scratch something.
I still think I may yank it off again and fabricate a way for it to attach to the passanger visor, that way i can just flip it down when passing throught the pickey counties and have it look normal for show.
-marc
-marc
https://www.crossfireforum.org/forum...343&highlight=
I better cross post this from https://www.crossfireforum.org/forum...pic.php?t=2343 as the orginal poster is from Texas:
Unfortunantly that work work for us in Texas. In texas the law is that you have to see the state name on the plate.
Senate Bill 439, Section 502.409 of the Transportation Code states that any bracket or frame such as dealership, sports team and/or college alumni that covers any portion of the word Texas or any numbers of the plate can now fine the driver $200.
Secondly in texas there is now a second law which states that you cannot put anthing on or around it that may distract from the numbers or distort it (clear covers, neon, etc)
There are somethings in the works that keep going up to the state to remove this stupid law... along with it goes 4.5 million in savings to the state to only issue one plate rather then two...
-marc
relating to an offense involving a motor vehicle with an altered or
obscured license plate.
BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF TEXAS:
SECTION 1. The heading to Section 502.409, Transportation
Code, is amended to read as follows:
Sec. 502.409. WRONG, FICTITIOUS, ALTERED, OR OBSCURED
[UNCLEAN] LICENSE PLATE.
SECTION 2. Subsection (a), Section 502.409, Transportation
(a) A person commits an offense if the person attaches to or
displays on a motor vehicle a number plate or registration insignia
that:
(1) is assigned to a different motor vehicle;
(2) is assigned to the vehicle under any other motor
vehicle law other than by the department;
(3) is assigned for a registration period other than
the registration period in effect;
(4) is fictitious;
(5) has letters, numbers, or other identification
marks that because of blurring or reflective matter are not plainly
visible at all times during daylight;
(6) has an attached illuminated device or [is a]
sticker, decal, emblem, or other insignia that is not authorized by
law and that interferes with the readability of the letters or
numbers on the plate or the name of the state in which the vehicle is
registered; or
(7) has a coating, covering, or protective material
that:
(A) distorts angular visibility or
detectability; or
(B) alters or obscures the letters or numbers on
the plate, the color of the plate, or another original design
feature of the plate.
SECTION 3. (a) The change in law made by this Act applies
only to an offense committed on or after the effective date of this
Act. For the purposes of this section, an offense is committed
before the effective date of this Act if any element of the offense
occurs before that date.
(b) An offense committed before the effective date of this
Act is governed by the law in effect when the offense was committed,
and the former law is continued in effect for that purpose.
SECTION 4. This Act takes effect September 1, 2003.
that:
(4) is fictitious;
registered; or
that:
detectability; or
-marc
In MA, if you get new plates, reserved plates or vanity plates (initials, names, etc.), you have to have a front plate. If you have an old plate, you don't have to. I have a plate that is 20 years old and I just keep transferring it from vehicle to vehicle so I don't have to have a front plate.
Originally Posted by Cruiser
I would hate to have them drill the front of mine. Soooo I carry the front plate with me, just in case I get stopped.
If I do get stopped, I am going to ask, if we could do the front plate out of vinyl. We can make it look just like the real one!
no plate or holes for me....what a way to ruin a beautiful front end. it's required in my state as well...i have been pressing my luck for 10 years in ohio...a couple warnings here and there but no tickets so far...knock on wood :wink:
the best line for the officer...the car was dealer traded from a state which did not require a front license plate and my local dealer has the bracket on order.
This will probably sound like a stupid idea and is probably illegal, but what about photo copying the plate onto a sheet of poster board and laminating it. Due to it being light and bendable (with quality velcro) = mount it to the bumper! I know ... I know :roll: = but if the state lifts the front plate rule ... a hair dryer would be all that's needed to remove the velcro strips with a little cleaning up afterwards and walla = no holes!
Originally Posted by CalgaryX
In the province of Alberta, Canada front plates are not required. They removed the requirement several years ago to reduce cost.
It is strange but prior to reading this thread I had not even considered the plate issue a problem to solve. But as I looked at several galleries on this forum, many of the pictures were san front plates. And yes the car does look better without.
There is little chance of driving in Korea without Front Plates. The Korean government has installed high resolution cameras that snap your front cars license plate if you are driving over the speed limit. The picture is then sent to your local district office and a bill is sent to your registration address. Pay the bill quickly and get a better rate. Forget and the charges double weekly. Yes, those roadway cameras work well even in the dead of night. Worst part is that you may be driving on a back country road and all of a sudden you are hit with a blinding flash.
Caught in the act! Cost ,about $45 dollars for 10km over the limit.
That's driving in Korea.
Screw front license plates. Colorado, like many states, require a front plate. Hah! All of my cars have never had a front license plate. If your worried about tickets when your car is parked, bring your front plate with you and place it on the dash. This has worked for me for several years. Never a ticket!
