Convertible windows intermitterntly creeping down when top up
Old 11-08-2016, 11:14 AM
leemeg99's Avatar
Default Convertible windows intermitterntly creeping down when top up
hi , I know there are plently of posts relating to convertible hoods but I am still having issues.
The windows in my roadster intermittently inch down together, this only happens when the top is up.
it doesn't happen all the time, usually does this for 15 mins then stops.
any ideas
thanks
Old 11-08-2016, 11:24 AM
Default Re: Convertible windows intermitterntly creeping down when top up
Both windows at the same time ?
If so, recall that there is a built in function that if you tap the top switch twice with the top up, both windows will lower.
Also, the "D" handle switch will lower the windows.
Could be an intermittent in either, or a problem in the central locking pump module incorrectly sensing that the windows need to go down. Is the CLPM dry ?
Old 11-08-2016, 01:23 PM
leemeg99's Avatar
Hi thanks, where is it located
Old 11-08-2016, 01:58 PM
which ?
The CLPM is under the trunk floorboard on the passenger side in a wad of foam.
The "D" switch is in the windshield header on the passenger side latch position.
Old 11-09-2016, 01:46 PM
any ideas
thanks
Do a search as this has happened before but as I do not have a roadster I never bothered to look into it at all.
