Detail Shop The place to talk about the daily care of your Crossfire and share the products you use to care for your Crossfire
How to detail your Crossfire!!
Old 11-11-2006, 07:48 PM
golfdude's Avatar
Default How to detail your Crossfire!!
Alrighty...I am sick and tired of having misinformed consumers on the market...this thread is dedicated to improving the knowledge of consumers on car care products. There are hundreds of products and techniques, so my techniques are not necessarily the perfect solution, but feel free to add more ideas and products on to my technique. Sorry for no pictures but I don't have a camera right now. So, here goes my techniques and ideas for the Crossfire, starting today with washing/drying via the Two-bucket method, and next time into polishing/waxing. If all of this sounds like too much, I detail cars myself, so please feel free to visit my website at http://www.cpcardetailing.com. Other than that, ENJOY:
1. Before washing the Crossfire (tips)...
- Raise rear wing (if necessary).
- Close windows.
- Make sure the vehicle has not been driven for at least 30 minutes.
- Park the car in the shade to reduce the chance of water spots occurring.
- Do not put any washing/drying materials on the floor or other dirty surfaces so that you do not introduce particles onto the paint, which will create swirls.
- ALWAYS use clean towels, sponges, and other materials on the paint surface...rinse often is necessary.
WHEELS
1. Supplies needed...
- Hose.
- Meguire's wheel spoke brush.
- Small foam waxing pad (I use an old eagle one wax applicator pad).
- Wheel cleaner (I use S100 GEL wheel cleaner, I used to use Eagle One A20 wheel cleaner, but it seems to have faded the clearcoat on the wheels because it is one of the most aggressive wheel cleaners on the market).
2. Spray S100 wheel cleaner onto the inside of the wheels and start to remove brake dust from wheels.
3. With hose and a strong stream of water rinse off the inside of the wheel (make sure to rinse off the brush often so you do not scratch the paint on the wheels.
4. Spray your waxing pad with S100 wheel cleaner and go over each spoke, inside crevices, on the sides of the spoke, and don't forget the hubcaps and the indentations within them.
5. Rinse off the wheel once again.
6. Spray inside the wheel well with the wheel cleaner and take a soft brush to scrub the area well, then rinse off the wheel well.
7. Take a rubber cleaner and scrub and rinse tires.
8. Repeat process for all wheels.
WASHING PAINTED SURFACES
1. Supplies needed.
- Your favorite car wash soap (I hear Optimum No Rinse works well, just make sure that the product does not strip wax).
- Two car wash mitts (sponges hold small rocks, which can scratch your paint once the rocks are exposed to the surface). One for the top 1/2 of the car, the other for the bottom 1/2.
- Two buckets, one for rinsing, and one for the car wash soap.
- Bug/tar remover (I recommend Poorboy's Bug Squash...works incredibly well).
- Bug sponge (soft sponge with net).
- Hose.
2. Spray the bottom half of the entire car...this will remove minor debris. To reduce the appearance of swirls, the key is to keep your water, sponges, and towels as clean as possible, and very gentle on the paint as well.
3. Focusing on the bottom end of the vehicle (I usually start with a side panel, then the front, then the other side, and then the rear, which is usually dirtiest), take your bug and tar remover, spray a small area, let is sit, and then gently take your bug sponge and remove tacky tar and bug spots, starting from the top of the bottom half of the vehicle, and working your way down.
4. Rinse area well, then rinse off the sponge, and repeat until the whole bottom 1/2 of the car has been treated to bug and tar product (rinse sponge as often as possible to reduce the formation of swirls on the paint).
5. Fill-up your rinse bucket all the way up...I recommend you get a grit guard for the bottom of the bucket so that your mitts do not get mixed in with the dirt.
6. Fill-up your wash bucket half-way.
7. Squeeze in a SMALL amount of car wash soap into the wash bucket...a small amount usually goes a long way.
8. Spray your wash bucket just for a few moments with water to allow it to sud, but don't fill-up the bucket all the way with water. because the suds will die-out eventually. My technique here is to activate suds on-demand, not once for the entire wash. This will help save car wash soap.
9. Dip both mitts into the rinse bucket.
10. With mitt #1, dip into the sudding wash bucket (suds provide lubrication between the surface and the washing medium, which will help reduce swirls).
11. Wash the roof first, then all windows, then put mitt #1 into the rinse bucket.
12. Rinse theses areas with water.
12. With mitt #1, dip mitt into the wash bucket (reactivate suds if necessary), then wash hood and half of the rest of the car, except for the rear of the vehicle (because it is the dirtiest part of the vehicle, it cleaned last), then put mitt #1 into the rinse bucket.
13. Rinse these areas with water.
14. With mitt #2, dip mitt into the wash bucket (reactivate suds if necessary), then wash the bottom half of the vehicle, top half to bottom half, but do NOT wash rear of vehicle. Put mitt #1 into the rinse bucket.
15. Rinse these areas with water.
16. With mitt #2, dip mitt into wash bucket (reactivate suds if necessary), and rinse the rear of the vehicle, not forgetting the small venture tunnels, spoiler, and exhaust tips.
17. Remove nozzle from hose.
18. Put the running water from the hose on the top of the car, and create a waterflow all over the paint, then work your way to the bottom of the car...this will remove a significant amount of remaining water on the surface of the vehicle.
DRYING
1. I like to use a blade...to use one safely, my motto is "With every swipe you wipe (with a microfiber towel)".
2. Tackle the windows first, then all surfaces that point to the sky, then sides, then bottom portions of a vehicle.
2.5 ...use a leaf blower or blowing end of a vacuum and remove water from all crevices, especially the front grilles.
3. Take a quality microfiber towel, typically a waffle weave towel for drying (I use the Sonus Blue waffle weave drying towel. Pakshack and Cobra are supposed to make nice towels too), and touch-up the areas not completely dried from the blade. Some common areas that need this include the side marker lights (water gets trapped inbetween the grooves), gills on the side, side mirrors, underneath the rear spoiler, side sills, and the rear hatch area (especially the upper portion of the rear hatch as water tends to sit there, eventually creating rust if not dried-up).
CLAY BARRING
What is a clay bar?
It is a piece of proprietary elastic material that is designed to remove contaminants within a clearcoat that cannot be removed through traditional washing. Vehicles that are not waxed and are not garaged are exposed to airborne elements that, over time, contaminate the clearcoat. Tree sap, paint overspray, embedded dirt, tar, bug remains, paint scuffs, etc...are some of the problem areas that a clay bar can remove safely without aggressive scrubbing with a towel which can create swirls and scratches. A rough paint surface can be smoothed-out by the use of a clay bar, and it's original paint color can be restored as the clay bar will reveal a contamination-free paint finish.
Recommended brands:
Clay Magic, Sonus, Griots, Erazer, etc...
How to use:
Before using a clay bar, make sure you wash the paint surface thoroughly to ensure that no loose dirt is on the paint. If the clay bar touches the ground, throw it out and use a new piece of clay since it will now have rock particles from the asphalt imbedded in the clay itself, which can scratch the paint. Always use some sort of clay lubricant in conjunction with the clay itself as it will scuff the clearcoat and create a hologram-effect on the clearcoat without use of a lubricant. Dedicated clay lubes, quick detailers, or car wash soaps can be used as lubricant, but as a warning, some car wash soaps are know to eventually break-down and eat away at some clay bars. I like to use Sonus Glyde as a clay lube or Optimum No Rinse, which in the long run saves money because of the less amount of product used.
1. Spray lube onto clay bar and 2x2 section of paint.
2. Take a 2 inch by 2 inch piece of clay, roll it into a ball, and flatten it out.
3. Gently glyde the clay bar onto the lubricated paint surface, and focus on keeping the paint surface generously lubricated in order to reduce the amount of scuffs on the paint. When the clay bar "grabs," that's when you know you are removing contamination within the clearcoat.
4. Rinse the area and repeat the process until all of the painted surfaces are clay barred.
Tip...check your work often as you might be able to see the spots that you missed by the darker shades of paint in the light. The more heavily contaminated a paint surface, the easier it is to see where the clay bar has done it's work.
when the clay bar gets excessively dirty, switch to a fresh side by flipping the clay bar over, or by rolling up the bar into a ball, stretch if necessary, and try to reveal a fresh surface from the clay.
M60A3Driver (05-27-2023)
Old 11-19-2006, 01:32 AM
golfdude's Avatar
Default Re: How to detail your Crossfire!!
POLISHING
First of all, it is my professional opinion that POLISHING is the most important step to make paint look it's best. A properly polished paint surface topped with a $2 wax will always look better than a surface that was not polished but topped with a $7,000 wax, I guarantee it! Polishing CORRECTS paint defects while WAX provides a barrier from the elements (some of the heavier waxes fill-in very minor swirls).
For explanation purposes, I will be using the Sonus DAS pads and Sonus SFX polishes because I feel they are very easy to understand. I have no affiliation with their line of polishes at all. I started out with this system, and I think it makes a great base for understanding the basics of multi-step polishing. The Sonus DAS Orange pad is a cutting pad, their green pad is a polishing pad, and their blue pad is a finishing pad. Within the Sonus SFX line of polishes, SFX1 is used as a rubbing compound, SFX2 is a basic, swirl removal polish, and SFX3 is a finishing polish.
note: Paint should be washed and clay barred for best results at this point.
What is polish?
Polish is an abrasive liquid that is designed to remove a super thin layer of clearcoat to remove scratches, swirls, and other minor paint imperfections. Automotive polishing is similar to wood sanding in that you need to do multiple polishing/sanding steps with decreasing levels of aggressiveness to perfect and smooth-out the clearcoat. Rubbing compounds are seen as liquid sandpaper as they are the most aggressive forms of polishes. A rubbing compound tends to haze the clearcoat. This happens because rubbing compound (SFX1), in combination with a cutting pad (Sonus DAS Orange Pad), removes a thin layer of clearcoat in a sloppy fashion, meaning the clearcoat itself is left uneven and rough, creating an uneven reflection. To restore shine to a paint surface treated with rubbing compound, one should apply a swirl removal polish (SFX2) via a polishing pad (Sonus DAS Green Pad). To perfect a finish and to further refine the reflection, a finishing polish (SFX3) can be used in conjunction with a finishing pad (Sonus DAS Blue Pad). On lighter paint colors, such as silver, this third step is not always necessary. I find a two-step polish works wonders on Saphire Silver Blue, while on some poorly maintained black vehicles, a three-step polish is necessary to perfect the finish.
When to polish?
Polish when your paint surface is showing signs of swirls (aka very light scratches in the paint). The best way to look for swirls in your paint is by looking at the reflection of the sun through the paint. If you can see many thin lines in the paint, you have swirls and they need to be removed. Swirls create a super-fine indent in the clearcoat, making the clearcoat uneven. This results in poor reflectivity of the paint since light is bouncing off of the clearcoat from multiple angles. By removing a thin layer of clearcoat, you are revealing a new, smooth clearcoat, resulting in a deeper, richer depth of shine and greater clarity of refection. Polish is recommended 2-3 times a year for the average vehicle.
Here's a picture of swirls on a Silverado I did a couple years ago. Note the lines revealed on the right side near the sun reflection:
How to apply polish?
Hand polishing takes forever, and I have rarely hand-polished paint, only small, hard to reach places if necessary. Nevertheless, the best way to polish is via machine. There are two types of machines used in detailing to polish...a rotary or an orbital. An orbital is a great start because it is very difficult to damage paint with it. The name "orbital" comes from the idea that the polishing pad both spins 360 degrees and oscillates slightly left and right to mimic a hand motion. The left-to-right movement dramatically reduced heat build-up, resulting in safer operation for the paint. An orbital machine is designed to run at very high rpms, max 6,000 rpm, in order to do the job. Here are my problems with the orbital polisher...it vibrates excessively, which can cause discomfort after many hours of use. The low heat production means it takes many more passes than a rotary to break-down polish to the point where it has to be buffed-off. The positive aspects of this machine is it's small learning curve, ease of use, and lower price compared to a rotary by at least $50. I recommend the Porter Cable 7424, it is very popular amongst the enthusiast detailer. This machine can do at least 90% of what a rotary can do, but it will take longer to achieve the same results. For those who are regularly exposed to severely damaged paint surfaces, a rotary polisher supplies the cutting power and speed to remove that damaged layer of clearcoat efficiently. The rotary gets its name from the fact that the pad is stationary and just spins 360 degrees always, no jiggling. This allows for fast heat build-up and fast polish break-down. The rotary is designed to be operated safely at speeds between 0 and 3,000 rpm's. The problem with the rotary is that its powerplant is designed for torque, whereas the orbital is all about top-end speed to do the job. With this in mind, if the rotary polisher is misused even at the slightest degree, it can jerk back quickly and violently, dramatically increasing the risk of paint damage. The high temperature build-up associated with the rotary means it can burn through clearcoat quickly when combined with an aggressive cutting pad and higher speeds. The rotary is a much more tedious machine to use, requiring concentration every second of operation, whereas the orbital can be tossed around without much care of paint damage. The rotary needs to be flat to 3 degrees angled in order to operate smoothly. Any variation from this means the polisher can cause holograms, additional swirls, or clearcoat burn to result. But, I feel the rotary makes a great companion to the Crossfire's incredibly hard clearcoat. Earlier this year, the rotary in combination with a simple finishing pad and a swirl removal polish made my SSB Crossfire's metallic flake pop like it has never popped before! Popular rotary polishers come from DeWalt, Makita 9227C, and Metabo. Prices range from $200 to $350 for the rotary polisher.
Using polish via a machine:
The idea here is to polish a 2x2 foot section of paint at a time. Furthermore, the rule of thumb is to try to use the least abrasive polish first, see if it does the job, and go to a more aggressive polish until you like the results. New cars rarely need any more than a swirl removal polish in order to look good, unless the dealership mistreated the paint when they "detailed" the car for you. If an aggressive polish is not getting the job done, try to stop using the aggressive polish and start the follow-up process. It took me a while to realize how effective refining the finish with less abrasive polishes had improved my finish. Make a circle on your polishing pad with your desired polish, spread the polish onto the paint surface, start your machine at it's lowest level and make a couple overlapping up and down, left to right passes, then increase to a desired speed. (I am typically at 5,000 rpm with the Porter Cable, and 3,000 rpm with the rotary for aggressive polishing). Once the polish has turned translucent, or the polish is beginning to dust, stop polishing and start buffing off the residue. Check your results in the sun to see how many scratches and swirls you removed, and if you are not satisfied, repeat the process or change polish and/or pad combination. You might have to go down in aggressiveness, or go up in aggressiveness. Each car is different but I wouldn't be scared to attempt a variety of different levels before you are satisfied. I am tired and so wax will be talked about next time! Enjoy and please feel free to ask questions.
When all was said and done for, this is what can result from a three-step polish and some Klasse All In One and P21S wax (sorry folks for not taking a picture from the exact same spot as before, but the whole car was basically bad). Keep in mind this vehicle was driven in the woods almost daily:
Crossfire tip: The Crossfire has very hard clearcoat, so don't get worried about using more aggressive pads on the clearcoat. This vehicle demands more aggressive techniques to remove swirls because soft pads will not have an effect on the clearcoat.
Ciro
Old 11-19-2006, 01:59 AM
blacklimitedcoupe's Avatar
Just a couple things to add about polishing with a rotary... As Golfdude stated, if you are inexperienced with the rotary, you can easily damage the paint. Be especially careful when polishing non-flat areas such as sharp creases or edges. If you keep the polisher over these non-flat areas too long, it can burn or even remove the clearcoat and paint. Also, remain steady with the polisher and keep a constant motion. Moving the polisher too slowly can burn the clearcoat, but moving it too fast will not polish to your satisfaction. Also, for fine cut polishing, such as removing fine scratches or swirls, DO NOT use wool pads. Stick with the foam pads as they are much safer. The wool pads are helpful when buffing a new paint job, but for fine polishing, I find that they cut too heavily. But I do agree, polishing is what creates the beautiful shine and wet-look.
If you do not own or want to use an electric polisher, a few coats of polish by hand, such as Meguiars polish will also produce a nice finish.
When removing the polish or wax, be sure to use a Microfiber towel as they greatly reduce the chances of scratching your newly polished surface.
Old 11-19-2006, 09:17 AM
Once again, thanks for the great job documenting this for us.
Old 11-19-2006, 11:12 AM
golfdude's Avatar
Detailing is my passion, so why not share it with others! Thanks for the comments. Blacklimitedcoupe, thank-you for the heads-up on towel selection and those important tips about the rotary. Wool pads are the most aggressive form of pad out there. Interestingly enough, the design of the pad does not create heat as fast as a foam pad because of the crevices inbetween each thread, allowing heat to escape more easily than in a foam pad, but they still are going to rip-up the clearcoat. I forgot the fact that some people still use cheapo terry cloths. Next post in the near future...WAXING and TOWELS!
Old 11-19-2006, 11:28 AM
BLC, I love the shine on your car, and I know you have used 3M products and a rotary buffer. My question is can I get that level of shine by hand and with some of the more available products you guys have discussed in the thread? I want my black roadster to shine like yours. I don't trust myself with a rotary buffer, never used one.
Old 11-19-2006, 11:39 AM
golfdude's Avatar
By hand you can polish, it will just take forever. Try Meguire's Scratch X after washing and clay barring. Work the product in well. Machine polishing is simply more effective due to the speed at which you can do it and the more aggressive pad selections you can choose from. After removing some of the minor swirls, your best bet is to fill-in the remaining swirls via a glaze. A traditional glaze is a non-abrasive liquid that fills-in minor swirls and scratches within a paint surface. It can be seen as an alternative to polishing, but it still is not as effective as polishing because you will not be able to remove some water spots and the deeper swirls in the paint. Try this stuff:
http://www.superiorcarcare.net/clvamowaxhag.html
Wax your car after applying the glaze. Oh, and, I used to use 3M Imperial glaze...it works decently well but it does not create as glossy of a finish as the Clearkote products, and it is a pain in the a-- to remove.
Old 11-19-2006, 03:58 PM
marauderroy's Avatar
Thumbs up Re: How to detail your Crossfire!!
Wow, Great info. I have saved this to my hard drive. Thanks so much for doing this.
Old 11-19-2006, 07:11 PM
andrew's Avatar
-C-I-C-C-I Associate Member
i don't know about their products but this is a good "how-to" link... (via emthusiast)...
http://www.adamspolishes.com/videos/Index.cfm
Old 11-19-2006, 10:18 PM
stryfox's Avatar
Good job, I would have a hard time explaining it any better myself.
I don't detail cars for a living but I paint classic cars full time.
Obviously I am buffing paint I just sprayed more often than factory paint but final polishing is key!!! To a wet looking job.
I use mostly 3m products.
For show finished I cut with 800, 1,000, 1,200, 1,500, 2,000 wet paper.
Than I cut with rotary polisher with a white wool pad and 3m perfect it II compound.
Then I cut with a white foam egg crate pad and 3m perfect it compound.
OK here is where the info is use full to you.
I polish with a gray 3m foam polishing egg crate style pad using 3m perfect it II foam polish pad glaze for dark colors.
Then I polish it with the same pad and polish but with an orbital.
I have been using this process for 10 years now. I have never heard and complaints about gloss at any major national car shows.
Old 11-22-2006, 12:29 AM
Well written and good information, golfdude.
I remember now, I used to have a life but then I discovered detailing.
Regards.
Old 11-23-2006, 02:37 PM
FPM - Yes, you can get that shine by hand, you just have to work at it. I actually have never used a rotary buffer on my crossfire. When I first bought the car, I used a random orbital buffer with a 2,500 compound to remove some of the swirl marks. However, since then, I have been polishing by hand only.
1. Clay bar your car so you can start with a good finish.
2. Take a microfiber towel, cut it in 2 pieces so you can use it to apply 2 coats of polish. Fold one of the pieces and pour a small amount of Meguiars Deep Crystal polish on it. Apply the polish to the entire car in a straight back and forth motion. Let it dry for about 5-10 minutes and use another microfiber towel to remove the polish, turning the towel often.
3. Repeat step 2 again
4. Using another microfiber towel piece, apply a coat of Meguiars NXT tech wax in the same fashion as the polish. Let wax dry about 20 minutes and then remove with a towel.
5. Apply a coat of Liquid Glass in the same fashion as the polish and wax. Let dry and remove.
6. Follow up by misting the car with TW ICE spray, one panel at a time. Use a clean microfiber towel to wipe it off.
I think you'll find that these steps will make your car look very nice by hand. If you still have swirl marks, you can either follow golfdude's tips with the rotary, or purchase a random orbital buffer and use that. I can give you some advice on how to use the R.O. An electric polisher is easier and can remove more scratches/swirl marks as long as you are experienced. I have found if you maintain your paint, you can keep it looking great by hand. Once a week I apply a coat of polish followed by a coat of NXT or liquid glass. Let me know if I can answer any questions for you.
Old 11-23-2006, 03:03 PM
Thanks, I am considering the Porter Cable orbital polisher used on the instructional videos, Please see the"for the detail experts" thread for my question.
Old 12-01-2006, 01:36 AM
golfdude's Avatar
So, you just corrected your paint imperfections via polishing, and now you want to form a barrier against the elements in the air. What to do? SEAL and/or WAX your car.
A sealant can be seen as an artificial, manmade alternative to wax. Sealants tend to provide much longer durability because of their manmade materials, but the finish can sometimes be less "warm" in comparison to a vehicle that was waxed with a carnauba-based product. Meguire's NXT paste wax is actually a sealant because it's main ingredients are high-tech polymers. A true WAX is a carnauba-based paste...carnauba is the main ingredient, as well as rich oils to enhance the wet-look appearance. Most sealants are able to be layered, depending on if they do not contain any abrasive materials within the, while waxes are able to be layered. Some waxes and sealants tend to demand a "cure" time before the next layer has to be reapplied. Some sealants, such as Klasse Acrylic glaze, works best with a sister product (in this case, Klasse All in One). Furthermore, some sealants can be topped by wax. Typically, I would seal and then wax, but I do believe some of gotten away with the reverse of this. There are all sorts of different sealants and waxes to choose from these days, some are easier than others to apply, some last longer than others, etc... To set a simple foundation, in terms of waxes, P21S and Pinnacle Souveran are regarded as some of the easiest to apply and remove, and achieve excellent results (lower longevity though). Optimum Spray wax (carnauba-based) has left an incredibly slick surface to my Crossfire, and it last a couple months too. Collinite 476S wax is much more difficult to apply than the previously mentioned waxes, but it is regarded as one of the longest-lasting products on a paint surface too, and I think it still delivers a nice shine. On the sealant end of things, my personal favorite is Menzerna Full Molecular Jacket. It is a water-based liquid. UPP paint sealant, Klasse Sealant Glaze, and Meguire's NXT are all other well-known sealants, NXT being the hardest of this group of sealants to apply and remove. Even before a sealant or a wax, a paint cleaner like Klasse All in One or Meguire's paint cleaner wax works well to enhance gloss (All in One) or fill-in swirls (Meguire's paint cleaner). Be careful though, paint cleaners have chemicals that will remove waxes that are currently on the surface, that's why paint cleaners can't be layered and should be used before applying a sealant or wax. In terms of application, a simply microfiber applicator pad or foam pad works just fine by hand. I wax/seal by hand. P21S by hand is so easy. Some waxes/sealants/paint cleaners require that you immediately buff-off what you applied (Klasse All in One, P21S), while other products like Klasse Sealant Glaze and Megiure's paint cleaner should be applied to the whole car and then buffed-off. At this point you should take a microfiber towel and remove the residue by hand. If it is difficult to remove, a shot of quick detailer should make removal easier. To make things even easier, I use the Porter Cable 7424 and the pad that comes with it to remove the wax by putting a microfiber bonnet onto the pad.
Old 12-31-2006, 11:26 AM
Gwetoe's Avatar
I have come across a great wax made by turtle wax. It is called ICE. It always leaves your care looking wet and does not leave any of that white residue on the car. Plus it is safe to use on the plastic trim!
Old 12-31-2006, 11:51 AM
andrew's Avatar
good stuff ~ https://www.crossfireforum.org/forum...&highlight=ice
Old 12-31-2006, 06:18 PM
golfdude's Avatar
Soon I will succumb to trying this stuff out too, but for now I must ask if you have ever tried some of the products recommended in the thread. I hear the Turtle Wax Quick detailer does not last that long.
Old 01-13-2007, 09:00 AM
I don't know if anybody mentioned this but I always do my tires/wheels first. It seems like they take the most time. And don't forget your wheel wells. They more or less "frame" the tire so get the mud and debris out of the wheel well. Mine are black so I make sure if there are stains they get some black paint.
When you dry your car (I use a leaf blower and 100% cotton towel) don't forget under the hood. A few minutes wiping things off will pay off in the long run.
Pat
Old 01-13-2007, 12:28 PM
golfdude's Avatar
Pat
I was hoping that people would notice to do the wheels first since it was the first section of the car that I talked about cleaning in my first post. Nevertheless, good reminder about that and the wheel wells too. With the wheel wells, I first spray the wheel well with water, then just take the wheel cleaner I am using, spray the wheel well, then scrub with an old toilet bowl brush I use. Just be sure to rinse well and don't let the brushes touch the paint. Gooooood point about the leaf blower, as that works wonders if your car has been protected by high-quality sealants and waxes...water should just run right off. Since I don't have a leaf blower though, I take the "blow" end of my vacuum and use that to get water out of specific gaps on the body, like the side strakes and front grill. As for the cotton towel, it's good stuff, but I do recommend you try a waffle weave microfiber towel, like the Sonus ones I use. There is no comparison to the level of water it can hold compared to a cotton towel.
Old 01-27-2007, 04:24 PM
xfire1's Avatar
Originally Posted by andrew
hey andrew...
last year you had posted a vid (link) of a detailing technique that is done LITERALLY by his bare hand and costs thousands of dollars. do you recall?
if so do you still have the link... i am searching thru the XF forum search but still can't find it...
thanks...
josh
Quick Reply: How to detail your Crossfire!!
