Ignition Wiring
Re: Ignition Wiring
To answer your first question, yes the chip is in the car. It is secured in the Universal Bypass by DEI that I listed in an earlier post. With the Advanced Keys system, the key fob that they provide has to be within the car for the car to start. How it works is when you walk up to the car there is a sensing 'perimeter', if you will - a radius of about a foot around the car where the system will detect the key fob. Once the key fob is brought within range, the system activates the DEI bypass module, which then sends the chip signal to the SKREEM module, allowing you to start the car. Without the key fob within that perimeter, the car won't start; even if someone breaks into the car and presses the button. In fact, without the fob in range, the push to start is completely deactivated. So, if someone were to break your window and try to push the button, nothing will happen. They can't even turn the car to the accessory position. To actually jump the car, the thief would have to be pretty knowledgeable in how the system works to bypass the key fob security feature. I could get into the details of how, but I guess that would turn this into a how-to-steal-a-push-to-start-crossfire thread
tcar32909
09-19-2015 03:51 PM
