mercedes rims
on
on
Re: mercedes rims
Really nice. Be sure to find out the offset so you can figure out if you will need sapcer. My wheels are 18x8 and 18x9 and required a 10mm spacer in the rear. This is because our stock wheels are 22ET rear and 32 or 35ET front. There are some advatages of using OEM style MB wheels. One is that the wheels have enough clearance in the front for the center caps. MB has a think bearing cap that interferes with many aftermarket wheels which is why many people end up needing front spacers. MB wheels can also be cheaper if you shop around.
on
1 Post
Re: mercedes rims
ALSO look closely those rims say AMC not AMG it might not bother you but it would bother me to the point of buying some used sl rims not mark off AMG rims... Just pointing it out.
HERE IS WHAT I FOUND GET THEM WHILE THERE HOT $650, $70 for shipping same SL 18's.
http://www.mbworld.org/forums/showthread.php?t=208697
on
Re: mercedes rims
Originally Posted by ShawnQ
I'd like to buy a pair of wheels for the rear of the XFire, in 17" preferably...just for mounting drag radials.
Does anyone have a recommendation for a pair of wheels that will fit the rear of these cars, in 17"?
I assume 17's will clear the brakes?
Thanks,
SQ
Thanks,
SQ
Edited: forgot the link:
http://cgi.ebay.com/ebaymotors/17-Me...QQcmdZViewItem
Re: mercedes rims
I would love to get these on my white roadster.
What would I do about the centercaps though?
http://cgi.ebay.com/ebaymotors/19-Ca...spagenameZWDVW
on
Re: mercedes rims
If those are white wheels you would want the matching center caps. You can get generic center caps, i have a set, but they make the wheel look kind of cheap. I switched to all silver Mercedes caps and got so many compliments that I am now running the nicer silver caps with chrome mercedes star.
The offset is good. The fronts will fit with no spacer but you will need 10 or 12mm hub centric spacers on the rear.
on
Re: mercedes rims
Originally Posted by ToplessXFire
WOULD THIS WHEELS FIT. FRONT OFFSET 35/ REAR OFFSET 30. THE WHEEL SIZE ARE 18X8.5 FRONT/ 19X8.5 REARS/ 5X112. ANY SPACING NEEDED NON SRT THANKS MIKE
on
1 Post
Re: mercedes rims
ShawnQ,
Go with a 16" and both BFGoodrich and Hoosier tire make 255/50-16 Drag Radials. If you use a tire calculator they have the overall same dimensions as the 19" rears. You can find Nitto's have 19" drag radials but they are a small fortune. I hear the hoosiers have the softest compound of the three brands. Most these tires brand new only have 6/32 of tread. Forget about TPMS.
Cruzinquick
Cruzinquick
Re: mercedes rims
I wonder if they sell "Folex" watches along with the "AMC" wheels. LOL
