Tire Size help
Old 09-03-2008, 05:51 AM
Sodamhot's Avatar
Default Tire Size help
I just got another set of wheels. Front 19x 8.5 Rear 19x9.5. A good friend of mine has a barly used set of tires. the front are 235/35/19 and the rear is 275/30/19 will this work well on my crossfire Will I have any rubbing issues in the front?
Old 09-03-2008, 06:07 AM
maxcichon's Avatar
Default Re: Tire Size help
Please use this tool:
http://www.rims-n-tires.com/rt_specs.jsp
I think it will depend on your new offset.
Old 09-03-2008, 11:54 AM
Sodamhot's Avatar
the offset is 35 and 35
Old 09-03-2008, 12:40 PM
maxcichon's Avatar
Front is the same.
The rear is 23 mm (.9") closer to suspension and is .3" smaller in radius. It won't fill the wheel well as much. 275/35X19 would be a better fit.
It looks to me as though you need spacers in the rear.
Use the tool I posted earlier-it's really easy and fast too.
FYI, Front offset 35 mm and rear is 22 mm (stock).
Old 09-05-2008, 06:08 PM
Max, thanks for the link...was very helpful as I will be needing tires in the near future,thinking of putting 275/35 on the rears..
Old 09-05-2008, 08:47 PM
maxcichon's Avatar
My pleasure.
BrenLW
08-05-2015 04:53 AM
onehundred80
08-02-2015 11:37 AM
onehundred80
Canada
07-24-2015 03:50 PM
crymar
07-17-2015 08:46 AM
syfi
07-12-2015 05:59 PM
Quick Reply: Tire Size help
