Morgan March
2004 crossfire 45k miles. This light keeps turning off in on in my car, supposedly it means coolant level low. Only issue is, my coolant is not low at all and I actually topped it off to try and get rid of this light. No luck at all. The AC keeps cutting in and out whenever the light is on. I took it to a mechanic this morning and they said they “checked everything and they can’t find a issue” thank the lord they didn’t try to charge me. I’m just wondering if anyone else on here has this issue
thank you in advance for the help!
well, I just recently had the same issue and I thought it was the coolant level sensor, I replaced that and got same thing, so I hooked my scan tool and threw me a code for the fan relay, the. I realized that the cooling fan wasn’t working and then I related the issue with the a/c problem, so I replace the cooling fan module, located on the driver’s side engine compartment close to the fender, that fixed my issues, good luck
