I bought a 2005 limited crossfire July of this year. (be sure to disconnect the battery before starting this) My problem was seats not working some times. I bought the seat relay on line and after removing the drivers side access panel I removed the heat and ac vent(note
nly one screw holds it in)then removed the two (2) screws that holds the head light unit. I pulled this unit to the back of dash and then was able to turn it to view where the relay is installed. I was able to remove the old one and replace it. This was much easier than trying to lower dash panel.
