Old Aug 26, 2025 | 02:46 PM
CaptArt's Avatar
CaptArt
Default Re: Magnetic clutch of the AC compressor
I recognize this is an old thread; but, I appear to have the same issue. Did you ever run the test? What were the results? I don't suspect a leak in my system, as it was working fine until the alternator failed. Upon replacing the alternator everything worked except for the air conditioning. I'm trying to determine if the is a cause/effect of disconnecting the battery to accomplish the alternator change. Thanks.
