Old Sep 12, 2025 | 06:22 PM
Romad's Avatar
Romad
Default Re: 2004 Door Locks "Automatically"
Here's how to turn the auto-door lock feature off.
2005 Hunt416 wrote: May2005
"The manual is wrong. The method for enabling or disabling the auto-lock is as follows:
Get in the car with the doors closed. Put key in Ignition. Press and hold the door lock button on the console (up to disable autolock, down to enable auto-lock). While holding the door lock button, turn the ignition to on. Do not start the car. Hold for about 5 to 10 seconds."
I discovered this by trial and error, and it was way back in September when I got the car, so I may be a little off on the exact routine. Good Luck.
IT WORKED FOR ME! WHEN I DID THE PROCEDURE I SAW THE FLASHING LIGHT GO "STEADY" AND I KNEW SOMETHING DIFFERENT HAD HAPPENED.
