Old Sep 15, 2025 | 01:44 PM
zip439's Avatar
zip439
Default Re: Gas in the Charcoal Canister
Originally Posted by Robskytoon
I had a fuel leak from under car and was from the charcoal canister but it happens when the engine is NOT running but ignition on so pump running. So today removed pipes from the fuel filter/regulator the one that goes to the canister was full of fuel so guess that the diaphram in the filter/regulator has failed so changed out F/R but can't test at moment because one of the new clips failed on install so fingers crossed its fixed when i get some more clips
be sure all liquid gas has drained out of the charcoal filter and give it a chance to air dry before hooking it all back up.
