Old Sep 19, 2025 | 08:49 AM
xintersecty's Avatar
xintersecty
Default Re: Trunk floor pan rusted out. What to do?
Originally Posted by Romad
Haven't given a whole lot of thought to the repair but the rust cancer is quite extensive. There just isn't much metal left. I'm "thinking" cut out all that is not stable, screw a 1/4" plywood from the bottom to create a floor, lay plastic sheeting on top hardware cloth, use 1/2" hardware cloth to form the floor and side walls, lay chopped strand fiberglass with resin. Followed by matting on bottom underside. Better than $1000 - $1300 the body shop wants! (Ridiculous amount for maybe about 3-4 hours work!)
Not a bad idea for a repair. The 1300 the body shop wants is for a proper repair. What your are proposing is fine but it's not a welded steel body. If you do go with your solution, use parchment paper on top of the temp plywood support as a release.
