Old Sep 23, 2025 | 09:40 PM
  #8753 (permalink)
Valk
A tech friend here posted this on his Crossfire.
I just purchased mine and installed it today.
Just connect the Negative and Positive wires to your battery and attach it to the top with the small 3M two sided tape provided.
It provides this info via Bluetooth on an app on the phone provided with the item purchased
Also has a GPS to indicate where your car is located
NOTE: Battery temperature is after driving about 40 miles at 83 degrees
Its inexpensive and available on Amazon
<u><b>BM200 car battery tester</b></u> BM200 car battery tester
Car turned off Voltage
Car running / voltage charging
Charging Test / Voltages based on RPM's
Cranking Test Results
