Old Sep 30, 2025 | 07:25 AM
Romad's Avatar
Romad
Default Re: Anyone know how to increase the idle?
THIS IS OFF THE TOPIC BUT RELATED: I know i have issues with the clutch assembly. Instead of engagement somewhere around the middle of clutch pedal travel it's at the upper pedal's travel. I have a new clutch kit but am thinking of holding off for a while. The clutch disk does not slip when holding brake and trying to make it slip when putting it in 2nd or 3rd. "Supposedly" a new disk was installed last year. I'm suspecting a weak pressure plate. I have bled the slave cylinder three times "but" dirty fluid may be a contributing factor as there was a lot of moisture in it. I'm making a power bleeder for replacing all fluid in clutch and brakes as they share the same reservoir. Just waiting on a brass hose fitting.
