Old Sep 30, 2025 | 07:32 AM
Romad's Avatar
Romad
Default Re: Manual tranny pedal engagement question
I know I have issues with the clutch assembly. Instead of engagement somewhere around the middle of clutch pedal travel it's at the upper pedal's travel. I have a new clutch kit but am thinking of holding off for a while. The clutch disk does not slip when holding brake and trying to make it slip when putting it in 2nd or 3rd. "Supposedly" a new disk was installed last year. I'm suspecting a weak pressure plate. I have bled the slave cylinder three times "but" dirty fluid may be a contributing factor as there was a lot of moisture in it. As mentioned above, I'm making a power bleeder for replacing all fluid in clutch and brakes as they share the same reservoir. Just waiting on a brass hose fitting. (Too lazy to go to the hardware store, so eBay it.)
