Old Oct 5, 2025 | 08:51 AM
zip439's Avatar
zip439
Default Re: 2004 Xfire Needing Ball Joint Replacement Advice!
Originally Posted by Romad
Well I guess what it is, is what it is. The alignment is good for a year so after I do the ball joints I'll go back for a follow-up alignment. The caster and camber were good and all they adjusted was the toe in.
Without eccentric bolts on the lower control arms ( A frame) the only adjustment is toe.
If you are doing this yourself you will need a coil spring compressor for Mercedes; It will fit up inside the coil spring then you tighten to compress spring. The spring compressors that mount on the out side of the spring won't work.
