Old Oct 8, 2025 | 02:51 PM
zachgo srt6's Avatar
zachgo srt6
Default Re: SRT 6 Crank No Start and 0 RPM reading while cranking
Also, after cycling the crank and no start, I hear 2 clicks and a constant humming or buzzing while under the hood. They come from around the throttle body/MAF. I have read that this could be due to a bad relay or solenoid but I wanted to hear anyone's input. Another symptom thats going on intermittently is when I turn the key to the on position, I can not shift outside of park. It takes several tries of turning the key off and then on to MAYBE get it to go into neutral. I'm wondering if all of these issues could be from one root cause or if they are more likely separate issues. I have not done anything to the RCM except for make sure the fuel pump fuse looks good... and it does. Any help or thoughts would be much appreciated.
