Thread: 04 electrical
Old Oct 14, 2025 | 11:33 PM
Lomzy1's Avatar
Lomzy1
Default 04 electrical
Well just got a good deal on a running 5sp but many issue to sort out surprise no surprise.
- blower motor resistor
​​​​​​- low beams not working
- no brake lights
- right turn signal light on dash constantly illuminated, not working and sorting hazard switch out if presses.
-bas esp light on brakes need work
- valve cover gasket leaking on exhaust and stinks
- headliner completely detached
- clunks from suspension on different corners when flexing
right now I’m just concerned about the bad esp issues and electrical lighting stuff.
brake lights not sure yet. Nothing comes when pressed but I hear relay switch working. Does that mean the actual brake switch is also working?
turn signal light on cluster I’m thinking multifunction switch. I disconnected all light switches switches and Harvard switch and nothing killed the lights from being illuminated except yellow relay in fuse panel.
thoughts direction?
Most problems s easy and solved but the turn signal and brake issues I need assistance
