Old Oct 17, 2025 | 10:30 PM
zip439's Avatar
zip439
Default Re: Antilock Brake Controller issues with 5 volt circuit
There is no programming required. Simply remove control unit and replace with another from same model type. The 2007 and 2008 units should be replaced from a donor of the same year just to be on the safe side.Those model years are a bit different than the earlier years.
I may be wrong on that, perhaps all years are interchangeable I’m just not certain, but regardless no programming is required.
