Re: Drag link removal NEED HELP
appreciate the reply I understand how to do the removal and Its the mounts at the pitman and idler hat will not come loose. The nuts are off. The service manual says to use the Miller tool 9168. I have a pickle fork as well as a ball joint separator that worked great on the tie rods but will not fit correctly on remaining 2 Heim Joints pressed in to the dragline. I can't swing the hammer do to my arm nor have the strength
CROSSFIRE SERVICE MANUAL page 2391 Linkage 19-47 in Diagram Bolt Points are marked as #1 left and right mount points
