Rear suspension noise! Maybe?
Completed the front suspension yesterday and all is good up front. NOW I'm hearing noise from the rear and thinking worn bushings somewhere. Used a crowbar under both tires and when lifting don't hear anything. After checking all the various bushings I find nothing worn or obvious. I even took off the fuel pump over and nothing loose. I did find a 4" piece of tree back bouncing inside the cover. Looking at the drive shaft center support bearing I do notice some deterioration of rubber around it but not very serious as my best guess. For now I'm calling it phantom noise hoping someone else has had a similar problem. I do hear a squeek like dry bushing somewhere.
