mistykup
Well I was NOT expecting this. Thankfully, my husband was which is why he removed all the sides from the trunk.
I think the console should be next for good measure.
Any recommendations for how to clean the surface without flooding the compartment? Just good old fashioned elbow grease, kitchen cleaner and a shop vac?
I have used simple green spray with good success. I would wear barrier gloves of some kind.
ZERACER
Your air pump is likely toast. If you buy another on E-bay be sure to get the elect. plugs and at least 6" of wire with it for splicing. The plugs are likely corroded inside also. A good shop vac will help with the cleanup and POR 50 to treat the rust.
ZERacer always has good advice.
