Re: NO crank / SKREEM / and bypass
QUICK UPDATE.
Fuel Pump / filter and good RCM finally showed up yesterday. installed Relay and Pump. I pulled out all the bypass wires and installed the correct fuses as well. Turned the key and heard the beautiful sound of a fuel pump even more exciting was the starter cranked too!!. Poured in 5 fresh gallons and boom car cranked over and started right up. Only light on is the BAS which I am hoping is because the wheels are off. I'll get her on the ground tonight and test drive. Excited the SKREEM is functioning properly (at the moment)
Good day..
Note I just picked this car up and was told the SKREEM was the issue.
