Old Nov 3, 2025 | 12:40 PM
Romad's Avatar
Romad
Default Upper Control Arm Passenger side. Help!!!!
Today I thought I was gong to change the passenger side upper control arm. The drivers side I did a couple of weeks ago. There just has to be a trick to getting at the nut, on the tower, to remove the long bolt holding the upper control arm! I know the overflow tank has to re moved out of the way but the rubber grommet on the bottom won't let go. Sprayed WD-40 hoping it will help. I pulled back the heat shield for access but can't even get my hand down to it. Locking for some advice on "how " to
"get-r-done!"
I also at the same time thought I would change the front shocks as well. I have received two different brands of shocks and both times they seem to be too long to fit. Is it me or are they indeed too long? Am I not understanding something?
