Old Nov 9, 2025 | 08:01 PM
M60A3Driver
Default Re: Temporary Rough Idle during Warm-Up
Originally Posted by stlouistrucker
I've had this problem for about a month. Car starts right up. Runs smoothly. After two or three minutes, before the engine is up to operating temperature, in park or at a stop sign in drive it starts running rough. I can put it in neutral, rev it up a few times and it idles fine. If I don't rev it up and take off it bucks a little and is then fine. Then until the next day it starts and runs fine all day. No check engine light. 113,000 miles. This weekend I replaced spark plugs, wires, coil packs and the five crankcase vent hoses. No change. I didn't expect any of those to be the issue, but it was past due. As preventive maintenance I had D.J. refurbish my RCM in July. At about the same time I replaced the camshaft and crankshaft sensors. Both were Bosch. I'm thinking one of the O2 sensors. Any ideas or comments
What kind of gas are you using? Have you tried an injector cleaner? You can also check fuel pressure at the rail. It should be about 58 psi.
